Dear sitecom experts,
I recently got sitecom wl-357 for my 3g usb. I have properly followed the step by step installation that is on the sitecom manual. Now it tries to connect but nothing more. it detects the network but it will not connect. Please tell me what can i do? Thank you for your time.
Reset the router via the little hole in back/underneath. Then simply set it up again, properly. Below is a link for the manual it has a step by step walk through for setup to help you.
www.sitecom.com/showdownload.php?id=3779
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button. Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point. Hope it helps. By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****. I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost). However it does not fit the following types of routers,modems and accespoints: WL-143 WL-122v2 WL-114/WL-517 WL-114v2 WL-108/WL109 WL-111 WL-106 WL-025 WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
