Question about Fish Mate Gravity Uv + Bio Pond Filters/3000 Guv 315 (Fish Mate)
How often do i clean filter sponge and change bio media in gravity 8 watt filter thanks
Posted by garypatch on
  • damebochiew
    damebochiew Nov 03, 2012
    I think there are several ways you can do it. For instance here bio media they will give your all the information you need to carry out this task. Hope this will be helpful. Good luck!
Peter Freese
    New Friend:
  • 56 Answers
I find cleaning the filter sponge bi-weekly keeps my koi happy. Normally I change bio media once a year and never at the same time as I clean the filter. There are bacteria that colonize the filter that convert the muck into gases and nutrients. So if you clean them both at the same time you remove this cleaning crew and that can cause issues.
Posted on Apr 28, 2011
How to clean the filter on my stand mixer cuisinart
Poorly designed filter location (subject to flour dust), easily plugged. No provision for cleaning or user replacement. Best solution is to stick filter material over the filter to provide a pre-filter. You can easilr clean or replace this pre-filter. I used computer filter media with double-stick tape.
E
Mar 06, 2013 | Cuisinart SM-70 1,000 Watts Stand Mixer
What's a sponge filter?
In sponge filters water is forced through porous foam. Water flowing though the sponge allows the growth of a colony of beneficial bacteria which neutralizes toxic ammonia. Most sponge filters uses two sponges attached to one lift tube which is an advantage that the sponges can be cleaned one at a time, reducing bacterial loss.
Aug 09, 2012 | Fish
I have to have the choke all the way on in order for my bike to run, an when i do get it started it back fires an like its starving for gas, we didnt ride it much last year, went to put it away last season...
Did you clean the air filter ?. The bike will miss like hell if it is starved for oxygen.
The Air filter is normally a sealed box with a curved air intake and a rubber hose connected to the carburetor. Open the box and clean the sponge filter with petrol and squeeze it dry before reassembling. If you have access to 2T engine oil dip the sponge in it and squeeze dry before reassembling.Back firing does not indicate starving for fuel .
Mar 08, 2011 | Televison & Video
My Honda EX 650 portable generator had brown colored fuel in it and a lot of rusty stuff in the tank. I plan to recoat the tank with something like POR 15. So far I took the tank out, hooked up a platic...
Do a deep clean of the fuel ;lines,carb,filter and tank.donot coat the tank inside,if is too rusty try find a used one and also change the spark plug and do ahead clean.
Nov 02, 2010 | Honda 3000 Watt Portable Generator
Can I clean the air filters or have to replace them and if so how often? I would also like to know where I can purchase new filters if necessary. Thank you!
Hi Thank you for contacting FixYa. We love to fix things.
You havent mentioned what make of Vacuum you are using.
Assuming this is a Dyson then yes you can wash the filters, let them dry then re-use them. You can wash the sponge type filters using fairly liquid and running under the tap and squeezing out the dirt just like you would with a normal sponge.
The Hepa Filters can be cleaned using a power washer or by placing them in a pillow case and puting them in the washing machine on a low heat low cycle. Ideally you should not need to replace the Hepa filters but i would recommend you do so after 1 year.
Oct 26, 2010 | Vacuums
I have a fishmate gravity filter - requires 2 8 watt buls and I don't know how to remove the burned out bulbs.
bulbs are in the lid of the unit normally .just undo the srews or seal ect and put new one's in
Aug 25, 2009 | Fish Mate Pond Filter Compact
How to clean blade and screen
First thing you need to do is take it apart, which can be done pretty simply until you get to the actual blade and strainer. You will need to use the crescent tool, the one with two pins. Insert it in the blade, and turn it counterclockwise while holding the filter so it doesnt turn. All the parts should come apart easily.
i find the best way to clean these parts is using a small brush, not a sponge or rag.
Mar 02, 2009 | Jack Lalanne Power Juicer 250 Watts
How to get the clean off an ge coffee pot?
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Dec 21, 2008 | GE 106591 Coffee Maker
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Fish Mate Gravity Uv + Bio Pond Filters/3000 Guv 315 (Fish Mate) Logo
391 people viewed this question
Top Fish Mate Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Fish Mate Garden Expert? Answer questions, earn points and help others
