Question about Apacer Memory Apacer AU120 MP3 Player
My mp3 player may turn on, but not starting playing music....
Posted by alecsander_i on
  • 17,130 Answers
Connect to the PC and check the files downloaded on the player. Check if there are errors or format issues in the downloaded files. if so scan and check , delect and recopy the accepted files.
Also you might need to reset the player.
Posted on Apr 28, 2011
I just received a 1GB MP3 (1 inch by 1 inch) player for Fathers Day. Don't know anything about this thing. When I charge it via USB port on my computer, do I charge it with the switch turned off or...
Please follow the instructions below to know how to charge your device
To set your LCD "Darkmode"
Your valuable feedback would be appreciated if satisfied with my solution.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 18, 2011 | Mach Speed TRIO Onyx MP3 Player
Model M4304 mp3 video player plays music but
update firmware ! if didn't work , then take it to the service ! rate please ! best regards .
Jan 14, 2010 | RCA TH1101 MP3 Player
Doesnt play music
It depends sometimes some songs may be copyrighted and cannot be played on the Mp3............ But as u say ur able to play 67 songs............ Just format your Mp3 player...... Formatting the Mp3 Player: Connect the Mp3 player to the Computer.......... Go to My Computer> Right click on the Removable Disk and click on Format and click on Start..... Know reload all the songs back to the Mp3 player..... Good Luck............
Jan 19, 2009 | Insignia NS-DV2G MP3 Player
Mp3 is froozen it will turn on and off but will not play music
i formatted my coby 512mb mp3 player and now it turns on but wont play
Dec 28, 2008 | Coby MPC-848 MP3 Player
Forgot how to use my Insignia MP3 player.
Power up:
If the player is laying flat with the screen facing left, you will see a large circle button and two buttons above the circle. The button on left above the circle is the power button.
To start playing music:
Press the button in the middle of the large circle with a small triangle facing the right (the play button)
To stop music:
Pressing the same button mentioned above will pause the music while pressing the power button I first mentioned will turn off the unit completely and stop the music as well.
Nov 30, 2008 | Insignia NS-DV2G MP3 Player
Shaker wont turn on
you have to hold the play pause button until you hear a noise and music starts playing
Mar 04, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Zen stone mp3player....works but wont let me play music..
Here are a couple suggestions. Did you load music on? Do you have headphones in? Tried turning up the volume?
Feb 18, 2008 | Creative Labs Zen Stone Plus MP3 Player
Not playing music
No Music Files Problem solved
Plug the MP3 player to PC
In Windows XP open Windows Explorer and navigate to one of the music files
Try to play the file in Windows
If it fails, unplug player and once the player switches off carry out a reset
Reconnect player to PC and repeat the process described above
You may need to repeat this several times until the music file plays in Windows.
After this format the player using Windows XP
Select the removable hard drive, right click and select format
Choose Fat32, enter a volume label (for example GMP33005) and select quick format
If formatting fails try several times
Once format is succesfull reload your music files using the software that came with the player
Be careful not to exceed 2.5 or 2.6 GB (leave some free space as this might be needed for the player to work)
The player should now play the music files correctly
Sep 22, 2007 | Audio Players & Recorders
MP3 screen says 'NO FILE" when trying to listen to music.
try putting the music back on. if that dont work, all i can say is i hope you saved a receit
Aug 27, 2007 | GPX MW3836 MP3 Player
Help me please!!!!
probably a stupid question, but are you sure your music isn't copy right protected?
Jul 23, 2007 | Coby MP-C883 MP3 Player
Apacer Memory Apacer AU120  MP3 Player Logo
169 people viewed this question
Top Apacer Memory Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
vinayghl
Tom Chichester
Are you an Apacer Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
