IBM eServer xSeries 346 Logo
Posted on Apr 28, 2011
I am loading windows xp pro and it goes thru the instaltion till it goes to resart after restart it says there is no hard drive. i have run the rom iag, and it checks the hardrive oassin in all tests. how can i get the scsi drivers to load so i can contiue install help i am going bald pulling my hair out and i dont have any spare hair thanks. ibm x series 346 machine
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on May 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
12154
Points
89
Get a copy of xp pro service pack 2,or borrow dell xp cd of someone it comes with integrated drivers and installs all the way through,or disable sata in bios and give it a go worked for me
My computer act like it is coming on then when it gets almost to the end of loading up it starts making noises and says on the windows xp load up page. Then if i do f8 and i choose the option of...
Replace the hard drive. That is the problem. The windows xp is corrupted due the hard drive error. It cannot continue to load on windows. Replace your hard drive.
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
My windows is not starting up
Dear i have send some information of your problem.
i hope you can read it and solve your windows problem.
Thanks. Aman.
ok my situations is
when i turn my pc it goes thru the normal procedure of starting up. all the way till you see the windows xp logo then it just goes away and the monitor is blank (a black screen). i tried the repair and that did not fix the problem. when i try to go open thru safe mode it tells me that windows xp setup cannot run under safemode. setup will restart now. can you help please i don't want to loose all my information on my hard drive so i really do not want to reformat and start all over. thanks
My problem is the computer restarts agan soon after the windows opens. I installed a new drive and when I tried to install (from CD) it will only go as far as loading the files and drivers and then when it...
Download a program called dban. http://www.dban.org/download and mount it on a disc with another computer. Place the disk in your computer and reboot. While loading look for the boot menu option and push the button. If you missed it reboot again. When the boot menu comes up select cd-rom drive or dvd-rom drive. The program should start up. Follow the directions on the screen by typing in autonuke. The program might run for a long time(probably overnight). After it is complete. Reboot you computer, take out the disc and reboot with your original XP Pro disc. Hope this helps.
1helpful
My niece has a Toshiba 6100 pro laptop. it sticks on dll missing
Hi, there is a CD that comes with the laptop when you purchased. Load the CD to your DVD/CD Rom drive. and restart your Laptop. The laptop will boot to CD and it will say press any key to start to CD. Then wait till it stop and the screen give you to choose which you want install window or repair press R for repair. and this will repair or load the missing driver. Hope this will help you.
HH
My desktop PC Windows XP Pro hangs during resart only
try to use msconfig (on run) to see what programs run on system startup. some of these programs may be a malware that keeps on placing trash on your computer. i would recommend you download the Anti Malwarebytes and run it to remove the suspected malware.
regards.
Xp won't load to hard Disk
Your RAM modules could be faulty or needs reseating. If reseating doesn't work, try swapping them around from the other laptop to see if that works.
Hp compaq presario v3000 is not loding the OS, show an error
  • as you boot the computer, start tapping the F8 keys
  • From the boot menu, select Safe Mode
If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
Please get back, if you need any further help.
2answers
Hal.dll corrupt or missing
Does the Hard Drive have Windows on it? If not, install the Windows Me Floppy disk. Select Run With CD-ROM Support or RUN With Out CD-ROM Support. Any of the two. After it gets done loading. type the following. fdisk
It will ask you do you want to use extended Hard Drive use? Y/N
Press Y. Then you'll get a screen with 4 options. If Windows is on there type 4. And see what it says on your hard Drive.
If you wish to erase Windows and reinstall it, click 3. to delete the partition and it will ask to restart the computer.
Restart the computer and reload to the fidisk screen and press 1. and it Will install a partition "Not Windows" After the Partition is installed restart the Computer and remove the floppy. If it comes up saying No Operating System found. Then the Hard Drive is set to install Windows.
The cheapest Windows XP you can buy Is Home Edition for $99.98, witch some stores still sell, like BestBuy.
If you want to send the Laptop to me I can install Windows on it for you. I have Windows 95,98,ME,2000 Pro, XP Home, XP Pro and Vista Home Basic. Thats if you don't want to spend money on Windows. Just pay for shipping.
2answers
Crashing during Windows Setup
Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works. or remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one cheers!
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
