Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a side by side refrigerator and ice maker will not produce ice anymore
Posted by rshorts06 on
raj somaiya
  • 5,370 Answers
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Posted on Apr 28, 2011
I have a whirlpool side by side.water and ice in door,water runs normal but no ice.
Ken, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Jun 28, 2017 | Whirlpool Refrigerators
Ice maker not producing ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Nov 18, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The icemaker is not producing ice. Water is not going into the icemaker to produce the ice.
heatman101
Oct 30, 2010 | LG LSC26905 Side by Side Refrigerator
ICE MAKER
Your ice maker works off a different side than the water dispenser. Most times the water control valve is the problem yet it has 2 sides one for water and the other for ice. You can check the ice maker by filling with tap water. Let it freeze and if it dumps the ice and tries to refill I would say the water control valve part number 4389177 will need to be replaced. Sea Breeze
Aug 24, 2009 | Whirlpool GD5SHAX Side by Side...
The ice maker does not make anymore ice.It looks like the ice tray position upside down.I need help.
Hi
If the ice maker has completely stopped producing ice, then check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 05, 2009 | Samsung Refrigerators
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
KitchenAid door ice and water dispensers don't work
Hi
If  the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | KitchenAid KSRG22FK Side by Side...
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
Ice maker stop making ice for kenmore 106.56352500
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
578 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
