I have satellite l455d-s5976 toshiba dvd\cd-rom driver error.my cd-rom also cant display so would u please help me to install new driver?when I see my pc device manager it can say code 19 configuration error.
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Please remove any CD's DVDs present in the DVD Writer. and enter into BIOS settings on power on of laptop. check wether the hard disk is detecting or not. If hard disk is not detected, try to remove the hardisk once and keep it inside the laptop. Try it. hope the laptop will work...
Hello there, Newer Toshiba laptops usually have the ability to create recovery discs that will let you recover to "factory settings." Try this: 1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
5. When prompted enter the first blank DVD and select Ok
6. When prompted enter the second blank DVD and select Ok I hope this helps. Thumbs up if you think so.
According to toshiba ,This computer came with Windows 7 installed. However,since the computer was manufactured,there's been a new audio driver released for Windows 7. This is most likely the solution to your problem.If there are CODEC problems, this (driver) is how manufacturers usually correct them.
That means that the driver has not loaded properly. Go to www.toshiba.com and download the updated drivers and firmware for your model. That should fix it.
