You can use either an HDMI cable or a VGA cable to connect your computer to your TV. Your computer has both HDMI and VGA ports. You can use either ports but you cannot use both or else your video card will crash.
Thank you for visiting FixYa! have a nice day!
Hi.
What will need is male to male VGA cable to connect the laptop to the TV but make sure that the TV that you want to connect to supports PC input otherwise you will be wasting your time.
Regards.
If it's a new TV you need to buy a " DVI to HDMI" converter
I think you can use a HDMI cable to connect your machine to TV but you have to make sure that the TV have a HDMI port, most likely HD TV have that connection. If you want to make sure you can go to this link to check the where the HDMI port located on your machine.
http://h10032.www1.hp.com/ctg/Manual/c01849861.pdf
Hope it helps.
AnEspera
SOURCE: I have a presario 900
You need to configure it as a second monitor before using it - you do that in Control Panel Display.
