Microsoft Word 2003 for PC Logo
Posted on Apr 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I obtain free fancy fonts for microsoft word
Anonymous
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Apr 27, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
71
Questions
Helped
17547
Points
187
Click on the upper boxes where you can find an A colored with a line.. then you can choose any color of fonts you want..
Printing in italics wrong font
The typewriter just prints what is on the daisy wheel. If the font is wrong, you need another daisy wheel with a font you like.
With a computer and a Microsoft Word, you can have a thousand Fonts for free.
1helpful
Icons and fonts are too large
hi,
  • To change font;
  • Right click on free space on the desktop.
  • Select properties then under display properties select Appearance.
  • At the bottom is font size option.Select normal.Save.
  • Icons:
  • Repeat font change procedure selecting settings under display properties.
  • Move to screen resolution and re-set it.[eg to 1024by768 pixels].Save.
2answers
I have a very small font size on my aol mail. How do I increase the font size
You can increase the font size by going to your browser's settings and changing the font size from there. How to get to these settings depends on which browser you use. An alternative is decreasing the resolution of your monitor.
OCR documents not transferring correctly in Microsoft word as a readable document
Optical Character Recognition used to be a nightmare, but not so much anymore. Theres no secret skill and you probably aren't doing anything wrong.
Here's a few tips:
1. your DPI setting should be set at 300, however, 200 is best.
2. Font Size, should be set at 10 or 12 and large fonts 72, for instance, will scan as an image only.
Now Here's Your Biggest Problem:
3. You need either the OCR-A or OCR-B font, it's free at Microsoft if you have Word, at:
http://office.microsoft.com/en-us/marketplace/ocr-a-and-ocr-b-font-advantage-EM010263992.aspx
2helpful
I want gujarati & hindi fonts for MS word file .From where can I get it?
1. Need to download all the hindi font from the site http://salrc.uchicago.edu/resources/fonts/available/hindi/
OR
Instructions Things You'll Need:
  • Microsoft Office CD or DVD
  • Windows installation CD or DVD
  1. Click the "Start" button, then click "Control Panel."
  2. Double click "Add or Remove Programs" if you are running Windows XP or "Programs and Features" if you are running Windows Vista or 7.
  3. Click the program list entry for the version of Microsoft Office that is installed, then click the "Change" button.
  4. Select "Add or Remove Features," then click "Next" or "Continue."
  5. Click the plus sign next to "Office Shared Features" to expand the category, then expand the "International Support" category.
  6. Click "Hindi Font" or "Universal Font" depending on the Office version, then click "Run from My Computer."
  7. Click "Continue" to finish installing the font. Insert the office disc if prompted, then return to the Control Panel window. If you are able to view Hindi fonts in Word, stop here. If you are not, you may need to enable support for complex fonts in Windows. Continue to the next step.
  8. Double click "Regional and Language Options."
  9. Click the "Languages" tab, then place a check in the box labeled "Install files for complex script and right-to-left languages." Click "OK" twice. If you are prompted to insert the Windows installation disc, insert the disc and click "OK."
Read more: How to Download Hindi Fonts to Microsoft Office Word ' eHow.com http://www.ehow.com/how_6306649_download-fonts-microsoft-office-word.html#ixzz12qrgA6Vb
2.
If this isn't the word Gujarati: ગુજરાતી, in Gujarati then your computer probably doesn't have a Gujarati Unicode font installed and you will have problems reading the Gujarati section of this site.
Following are instructions for getting Gujarati Unicode to display properly on various computer operating systems.
Microsoft Windows Microsoft Office 2000 and Microsoft Office XP If you have a copy of Microsoft Office 2000 or Microsoft Office XP, or Microsoft Publisher 2002, and Gujarati is not displaying properly then you should install the Arial Unicode MS font which is distributed by Microsoft with these products.
If you are unsure how to install Arial Unicode MS from CD then please consult the Microsoft Help and Support website - try searching for "Arial Unicode MS".
Windows 98, Windows ME, Windows NT 4.0 and Windows 2000 Windows 98, Windows ME, Windows NT 4.0 and Windows 2000 are not distributed with Arial Unicode MS so you will need to install an alternative Gujarati font.
You can download the following free, open source Gujarati fonts from the Indictrans Project:
Padmaa Medium, Padmaa Bold
Once you have downloaded the font file you can install using the font utility in the Control Panel, alternatively just copy the .ttf files into your \windows\fonts\ directory. There are more detailed instructions on our installing fonts page.
My screensaver stops running. It will freeze for seconds or minutes, then start again. I've tried changing screensavers to no avail. I also get the popup that says This program is not responding frequently...
Many fancy screen savers on the internet contain Viruses that cause inconveniences like frozen screens. It is highly recommended on top priority that you should obtain a good Antivirus update it and scan your computer thoroughly other wise this frozen screen situation is bound to get worse.
If you want a free antivirus please download AVG from the following URL.
http://free.avg.com/ww-en/download-avg-anti-virus-free
Good Luck!
Plz remove the virus
SPEAKING WITH MY EXPERIENCE: Either try Security Essentials from Microsoft OR
Trend Micro. Trend has a free scan called Housecall.
Run and see what comes up.
Then download Spybot Search N Destroy.
Helpful Free Software below Read On.
FREE SPYWARE
Download Spybot Search & Destroy. Restart computer, then run Spybot to see what spyware comes up, AND DELET IT.
FYI---Virus Protection-- 2 programs of virus protection will conflict with each other and will actually cancel out the protection. SO just download one.
Running Spybot Search & Destroy with EITHER Avast or Avg (great Free virus protection programs ) will keep a computer in good working condition. FREE
HERE ARE SOME LINKS, THAT WOULD BE BETTER:
NEW *****Somthing new FROM MICROSOFT.*** 2009 ---Security Essentials
http://www.microsoft.com
Pop up Blocker ** free******
www.panicware.com
*****Spybot - Search & Destroy 1.5.2 ****
FREE SPYWARE
http://www.download.com/Spybot-Search-De…
****Avast ***FREE ANTI VIRUS PROGRAM
http://www.avast.com/eng/home-registrati…
****AVG ****FREE SPYWARE PROGRAM
http://www.free.avg.com
**Ccleaner*** FREE
http://www.download.com/3120-20_4.html?q…
***Malware**** FREE
http://www.malwarebytes.org/.
$ *** KASPERSKY ***
http://www.kaspersky.com
There are alot of $ anti-virus and Internet security programs out there,
ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 , I feel that is the best for your money.
REMEMBER TO KEEP UP THE DAILY MAINTENANCE ON ALL OF YOUR COMPUTERS.!
Good Luck. If you think this is good information, , please rate me.
2answers
I have microsoft word and my fonts are very limited.how can I increase the variety ?
you can download free fonts on this site HERE. download it and install.
  1. open control panel
  2. click or open the font icon
  3. on the file menu, select install fonts.
  4. select/search the fonts that you have downloaded.
good luck
Problems with Office 2000 after uninstalling free trial 2007
hello, you will need to perform a system restore on your computer. if you can remember the date you installed the 2007 then performing restore will be easier
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
