The white screen on Apple Products is never really a good thing.
You've probably heard of the blue screen of death(Windows) and the red ring of death(XBox), the white screen is referred to the white screen of death, normally not something you can recover from.
But try this anyway:
Reset the iPod:
- Turn the Hold switch on, then back to off.
- Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
- You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2
hours, then disconnect it. If you have a wall charger, plug in the
iPod, then follow these steps while it is still plugged in.
- Press and hold the Menu and Select buttons until the Apple logo appears
- Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the
computer and (assuming it shows up) reset the iPod again to get it out
of Disk Mode. If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary
tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
