Dell Inspiron 1525 Laptop Logo
Posted on Apr 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Start laptop windows xp start then go welcome screan then log off, I click log on, then go log off. I try and try but faild. I would never go windows inside. please help. I would also trying windows re-instal but faild. help help help. Feroz Al Mamun [email protected]
Anonymous
Level 2:
New Friend:
  • Expert 102 Answers
  • Posted on Apr 27, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
102
Questions
Helped
17357
Points
318
Did you try booting into safe mode? if not? try taht.. press f8 before xp bootscreen appear and select safe mode..if you can log onto your pc using safe mode.. click start>run and type msconfig and press enter.. a window will appear, click startup and check if there are any suspicious applications that are enable..uncheck it.. and run a full system scan with your antivirus..once done, restart your computer with the normal process..see if it works..good luck!
2answers
Can't get by password on window xp tough book cf-51
In this case, try to reset your Windows XP password by following the instructions mentioned on the link below and check if that helps:
http://www.wikihow.com/Retrieve-Passwords-in-Windows-XP#Windows_XP_Method_sub
GuruAid.com
3answers
I kept password for my administrator account..but when iam logging the computer it does not asking password...and directly opening the windows...i wants to keep windows should enter the password on windows...
1) Go to Control Panel on the start menu.
2) Double click on User Accounts.
3) Then under the Pick a Task heading select Change the way users log on or off.
4) Tick the box next to Use the Welcome screen.
5) Then click apply. Password or not when your computer starts up it will take you to the welcome screen where the user can select which account they want to log into.
How to fix blue screen when trying to start computer
it will depend the error message. however; you can try this.
start you computer on safe mode. (i am telling you this will depend on error message)
to start you pc in safe mode hit F8 key simultaneously. when the windows pop up. with you down arrow in you keyboard select. SAFE MODE only. (if you go trought your log in screen you will be lucky) . if so
log in as normal. click yes for safe mode question
(THE NEXT ADVICE IS ONLY IF SYSTEM RESTORE IS ON)
i recomend you if you can log in onto your pc in safe mode to do a System reestore. because the blue screen could be a bad driver or bad update that you recently did.
so to make an system restore follow this. To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as an administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
  3. On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.2425657.png
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete
HOPE THIS HELP
3helpful
Dell Inspiron blank screen
You can restore your system in your safe mode.
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
2answers
Start Menu Picture Disappeared Suddenly
Turn the Welcome screen on or off It sounds as if you accidentally turned off the welcome screen. Here's how to turn that function on and off:
To turn the Welcome screen on or off
You must have a computer administrator account on a computer that is a member of a workgroup or is a stand-alone computer to turn on or turn off the Use the Welcome screen feature. Logging on at the Welcome screen is not available on computers that are members of a network domain.
  1. Open shortcutcold.gifUser Accounts in Control Panel.
  2. Click Change the way users log on or off.
  3. Do one of the following:
    • To specify that users log on to the computer using the Welcome screen, select the Use the Welcome screen check box. A user logs on to the computer by clicking his or her user account name on the Welcome screen. If a password is assigned to the account, the user is prompted to type it.
    • To specify that users log on to the computer without using the Welcome screen, clear the Use the Welcome screen check box. The Welcome screen will no longer appear when you start the computer. To log on to the computer, type your user name (and password, if you have one) in the standard Log On to Windows dialog box.
note.gif Notes
  • To open User Accounts, click Start, click Control Panel, and then click User Accounts.
  • Fast User Switching is available only when the Welcome screen is turned on. For more information, click Related Topics.
I hope this helps. Please let me know if you require further assistance.
Missing files and photos, settings ect
Log in as Administrator and undo the system restore.
How to undo a system restoration after you perform a System Restore loadTOCNode(2, 'moreinformation'); You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
  3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
  4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
  5. Log on to the computer as Administrator. The System Restore Undo Complete page appears.
  6. Click OK. You can now run System Restore again from a different restore point.
I try to log on but it wont show my desk top
I think you pc is virus infected...
try to restore if ..............
  7. Click OK.
rate me ..
regards,
Will show avaliable wireless networks but won't connect
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
if the Issue presist then you need to try System restore
If Windows XP starts loadTOCNode(3, 'moreinformation'); 1. Log on to Windows as Administrator. 2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts. 3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. 4. On the Select a Restore Point page(try the date 2 dats prior it was working or the First Bolded Date of that month), click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK. 5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. 6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears. 7. Click OK.
1helpful
Change wellcome screan of windows xp
Disabling the Windows XP Welcome screen.
  1. Click Start, Settings, and Control Panel.
  2. Open User Accounts.
  3. Click "Change the way users log on or off".
  4. Uncheck the "Use the Welcome screen".
  5. Click "Apply Options"
Disabling the Windows XP login prompt for password.
Click Start and Run
  1. Type "Control Userpasswords2" and press enter.
  2. Uncheck the box for "Users must enter a user name and password to use this computer."
  3. Click Apply and Ok.
Dell c640
By default Windows XP displays the Graphic login screen with icons and usernames at startup.
If you would like to use the more traditional Windows NT login screen you can get to that screen by pressing Ctrl Alt Del (Reboot key sequence) twice.
If you would like to change to the traditional screen at login, instead of the graphic login screen, do the following:
  1. Log in with administrator access.
  2. Click on Start, Control Panel, and select user accounts.
  3. Click on Change the Way Users Log On or Off.
  4. Click on the Box "Use the Welcome Screen" so that there is not check mark.
If you would like to switch from the traditional login screen to the more graphic screen just click on the box in step 4 above so the "Use the Welcome Screen" box is checked
Cheers-Parveen
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
