Page 22 in the Manual details the required input to be selected dependent on the connection type. To enjoy sound from the TV (Page 29) AUX*1: When using an Audio cable ARC*1: When using an HDMI cable (Available when using an ARC compatible TV) DIGITAL IN*1: When using an Optical Turn on your TV and select the appropriate audio input mode Setting the audio link with the TV With the remote control; Select the actual TV audio connection on the main unit. 1 Press [START] and press [3, 4] to select "Other Functions" and press [OK]. 2 Press [3, 4] to select "Setup" and press [OK]. 3 Press [3, 4] to select "TV / Device Connection" and press [OK]. 4 Press [3, 4] to select "TV Audio Input". 5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN". Select "AUX" or "ARC"*1 in "TV Audio Input" when the DIGITAL AUDIO IN terminal is used for the STB connection. Whenever the connection or settings are changed, reconfirm
digital audio cable
And from Page 29
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
the points above.
Please leave feedback
Cheers
Andy
