If you mean you're trying to use DSL service with the modem that came built into an HP computer, you can't. That modem is for dial-up Internet service only, or if you want to use your computer as a fax machine along with a scanner or all-in-one printer.
To connect to DSL, you'll need a DSL modem. If you're just getting service, your service provider should have supplied one. (Actually, I think you have the option now of ordering DSL service and not getting a modem if you already have one. Maybe you did this.) The DSL modem has a telephone-type jack to connect to the phone line (same as on the HP modem), but the connection to your computer is through a different, larger, jack usually labeled "Ethernet" or "Computer". If you don't have a modem, you can easily find them for sale. You can buy new ones at retailers who sell computers, and many used ones are available on eBay or on your local Craig's list.
Another possibility is that you already have a DSL modem and are asking how to connect an addtional computer. If this is so, you don't connect the new computer to the DSL phone line. Instead, you need to share the network connection coming from the modem. This is done using a router, which allows several computers to use the same connection either through a cable or wirelessly. The DSL modems typically supplied now have the router built in, with 4 connections for wired computers and wireless capability as well. If your modem is an older one intended for a single connection only, it will have just one network connection. If this is the case for you, you'll need to supply your own router.
