when you say your hp photosmart will not turn on, do you mean it won't bring out any power or sign of light? If yes then it means the unit is having a power problem.
First, make sure there is running from the AC wall plug of your house into the unit. And be sure you don't have a defective power cord/adapter.
If non of the above seems to work then it means its actually having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Apr 26, 2011
May 28, 2013 | HP - HP Photosmart 8250 printer
Oct 31, 2010 | HP PhotoSmart 7760 InkJet Printer
Aug 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Apr 04, 2009 | HP Photosmart C4580 All-in-One InkJet...
Nov 07, 2008 | HP Office Equipment & Supplies
Sep 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
May 11, 2008 | HP Photosmart 2610 All-In-One InkJet...
Feb 16, 2008 | HP PhotoSmart 7960 InkJet Printer
Jan 03, 2008 | HP Photosmart E327 Digital Camera
50 people viewed this question
