I have a Funai VCR/DVD recorder, model no. B2737. It will not format DVD-R or RW discs and shows an error message 'E4 54037380'. I have tried using a lens cleaning disc, without success. Can you advise me as to ehat else I can do to solve this problem?
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
sorry...it seem like your dvd/vhs player is outdated...(do the rw disc plays in pc?) are you using Nero software? this will curve the problem...or try another DVD RW brand that funai is compatible with...dvd players, dvd recorder and pc dvd burners do roll back...all must be a year or less apart to work with each other....
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
