Question about Frigidaire Ovens
Over calibration off.
I have a Frigidaire Elite - Electri Clean single wall oven. It came with the purchase of our house, & I think it is about 15+ years old. I don't have the manual so I don't know the Model #. It is heating 50 degrees too hot. There is no way for me to calibrate with the heating knob. Does this mean I have to have an electrician come and fix it, and if so, would he have to take the oven out of the wall? It is installed under a built-in microwave & on top of that are cabinets. I can't see how anyone could take it out without tearing out the microwave, too. Am I wrong?
I cannot afford to get a new oven. I rarely use this one because even with a temp. monitor, it still doesn't seem to back things properly.
Any advice on this?
Thank you.
Posted by fcfalls on
David Spradling
    Top Expert:
  • Frigidaire Master
  • 11,303 Answers
Bad temp sensor
Posted on Oct 08, 2017
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Posted on Dec 11, 2008
Anonymous
SOURCE: No target appears on the calibration screen
I just got one of these for my 4 yo daughter and had the same problem after 2 days. GOOD NEWS IS IT IS FIXED. The problem was crumbs stuck between the edges of the screen and the frame piece around the edge of the screen. I assume this was creatintg pressure in 2 places at once, confusing the screen/software and not showing a target on the calibration screen.
I used a toothpick to remove the visible crumbs, but if you have a can of compressed air used for computer cleaning, than that might be even a better idea. It seems that screen problems were chronic back in 2004, but no so much now. I learned about this here: http://www.watercoolergames.org/archives/000028.shtml
GOOD LUCK and post back if it works as it is simple and maybe some of the other people with problems have ths same simple issue.
Posted on Dec 29, 2008
Anonymous
SOURCE: Calibration Failed
make sure speed sensor isnt to far away from left wheel or did not get unplugged from circut board
Posted on Apr 16, 2009
Anonymous
SOURCE: cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Posted on Jul 26, 2009
Anonymous
  • 6 Answers
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
How do I unlock the oven door when it won't unlock after cleaning?
Hello friend, thank you for your post!
Based off the information you have provided the door on your Frigidaire wall oven is not unlocking. Performing a reset on your oven can trigger the door latch to unlock, in order to reset your oven you would need to disconnect power from it for roughly ten minutes. If this does not resolve your issue with your oven you can also hold down the clear or cancel button for 10 to 15 seconds.
Another step you can attempt is to perform a self-clean cycle and before the cycle starts cancel it and that can trick your oven into unlocking. If these troubleshooting steps do not help correct the problem it could be a faulty door latch or control panel. I hope this information has been helpful. -Matt
Mar 14, 2015 | Frigidaire 30 Single Electric Wall Oven,...
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
What do the error codes for frigidaire elite electri clean oven
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Aug 02, 2014 | Frigidaire 24" Built-in Single Electric...
Wall oven will not heat
Have you tried replacing the element?
Apr 19, 2014 | Kenmore Elite 30 In. Electric Self-clean...
Inherited uncle's house that has an old electri-clean cookmaster oven. the element is not working but the fan comes on when you turn in on...can't find the serial number to get the look for correct part or...
Sorry to read about your problem, I hope this helps you out.
without the model number, you will need to have a service company, come and look at the unit,
tell them on the phone, that you dont have a number, and to send their most experienced person. then they can match a coil up....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Frigidaire 24" Built-in Single Electric...
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
How to calibrate double wall frigidaire ovens. temperatures are not true to digital control.
plaese post model number to assist you further. directions for calibration should be in user manual..
Feb 21, 2009 | Frigidaire 27 in. Electric Double...
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
113 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Ekse
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
