Asko 24 in. D3121XL Free-standing Dishwasher Logo
Posted on Apr 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Asko D3121 dishwasher won't turn on. When
Ginko
Level 3:
  • Asko Master 19,396 Answers
  • Posted on Apr 26, 2011
Ginko
Asko Master
Level 3:
Answers
19396
Questions
25
Helped
8073433
Points
55462
Hi.
There is no error code, then check the following:
1)Check that the problem is not overflow.. Remove the lower access panels and check the tray under the dishwasher. If you find it is full of water use a cloth to dry water. Test the overfill switch.
2) Disconnect power, move the appliance forward and check that the drain and inlet hose is OK. Be sure that the machine is filling. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray.
3) Test the door lock. This can be tested jumping its contacts.
4) If all the rest is OK you may have a defective control module. This is not a common fault. Ensure that all the rest is OK first, wiring and pump motor must be tested before going for control module.
Start checking for overfill, that is a very common fault that may cause cycle not starting
If you want to contact a technician use the number listed on the USE AND CARE GUIDE.
Regards.
Ginko.
Where is the reset button o a Asko TD11
Asko TD11 is a dishwasher model, and it does not have a physical reset button. However, there are a few ways you can reset the dishwasher: Unplug the dishwasher: Disconnect the dishwasher from the power source by unplugging it from the electrical outlet. Leave it unplugged for a few minutes before plugging it back in. Turn off the circuit breaker: Locate the circuit breaker that controls the dishwasher and turn it off for a few minutes before turning it back on. Press specific buttons: Depending on the model of the Asko TD11, there might be specific button combinations that you can press to reset the dishwasher. Consult your user manual for instructions on how to do this.
Mar 13, 2023 • Asko Dryers
Hi I cannot use the buttons on my ASKO dishwasher D5456.
How to Reset an Asko Dishwasher
  1. Press the "Start/Stop" button.
  2. Hold the button for three seconds and release.
  3. Select the program and options on the front panel you want the dishwasher to use. Press "Start/Stop" to restart the dishwasher. You have now reset an Asko dishwasher.
Can't choose just one option like "Rinse & hold" on the control panel.
try this
turn the machine on at the wall select what you want then press the start button
it is possible that you are trying to change the program after it is started and that is causing conflict
3helpful
2answers
Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
2answers
Model d3121 does not "heat"... when I use it the water don't be hot and the dishes doesn't dry. you can answer in french i'll try to understand ... as you can see i'm not bilingual but...
In my case, the problem was with the control card, located behind the control buttons on the front. The relay driving 120V, 10A to the heaters had one pin dissoldered, probably because of heating. It was dark around the pin. See the picture attached. The top part showd the PCB with the faulty pin marked by a red arrow; the bottom part shows the other side of the PCB with the relay itself.
Remember that this relay/pin drived 1400 W.
I found the electrical drawings here:
http://www.greatplainsapplianceparts.com/order/Parts%20Manuals/Asko/ASKO-Dishwasher/D3121%20%28DW20.1%29%20SS.pdf
7helpful
3answers
F4 problem
f4 fault means set to time fill,turn power off wait 5 sec then press and hold prog and start buttons in and turn power on wait for previos fault to show then release.then press the programme button the dishwasher will show 1 and start filling,press and hold prog button until it stops filling then press prog button until 4 shows on display,then press start finished,turn off then on and test on cycle.
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
