Intermatic T104 24h 208-277v Mechanical Time Switch Logo
Edward Alarcon Posted on Apr 26, 2011
Proper wiring for 220 volts timer - Intermatic T104 24h 208-277v Mechanical Time Switch
A
Anonymous
You posted under T104 timer.
Open following links for wiring information and diagrams.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/B220C.html
You say 220Volts and I use 240Volts = same thing
T104 is 240Volt timer with 240V WG1573 clock motor
240Volt cable has two hot wires that arrive from breaker box. These wires connect to terminals 1 and 3.
240Volt cable going to Load has two wires. These wires connect to terminals 2 and 4.
Bare ground wire connects to green screw.
If your timer has terminal A, then terminal A is not used unless you are converting timer for 277Volt operation, or some other specific wiring purpose, or if your 240Volt cable from breaker box also has a Neutral wire, in which case the Neutral connects to terminal A.
If you have different brand timer, or different model number, then add a comment with model number that shows inside timer door, and I will search for wiring diagram.
http://waterheatertimer.org/Boxtype.html
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
  • Anonymous May 08, 2013
    This is aDTMSLD1 on delay 220v timer with A1 and A2 terminal connections on top and 15,16 and 18 terminal connections at the bottom. Please advise wiring
Can i use a 220 v timer for 110 v and if so do i have to add any jumpers or switch motor wires
220 Volt timer on 120 Volt will cause the timer motor to run slow and burn up
Can we wire with 220 single phase
It should be all set for 220 volts, a 3 phase timer would be twice that size if they make one. Little things don't run on 3 phase power. Are you just running the lights with it? If so, you don't even need the 220, just one side of it will do, make sure you have a wire to the clock motor, should already be there, check it out, Hope this helps.
Timer motor does not turn
make sure you purchased nthe correct timer and not a 220 volt timer for water heater use , you could still turn on and off manually but you would need 220 volt to run timer may sound silly but i have seen it several times before , look on the door plate and be sure it is a 120 volt 1 phase tmr motor
I want to make my 110 volt generator into 220 volt
most generators have a 220 volt plug on them from the factory, if it is a small one it might not have the capabilities of 220. If it has the 220 plug then you will just need to wire the proper 220 male end onto whatever you are trying to run.
1helpful
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 • Dryers
Top Intermatic Electrical Supplies Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
