Question about Malber P21 Front Load Washer
Where can I get a new handle for the washer? How difficut is it to put on?
  • Malber Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on Apr 25, 2011
Plastic handle on lid broke. Is there a replacement part for this?
Rival cookers are now crock-pot.com. The parts page for your model shows no parts available, but there's a "contact us" link. You can try that and see if they can recommend a replacement handle from another model that might work.
When a friend's cooker needed a new handle, I went to Home Depot and picked up a plain wooden drawer pull and a flat rubber washer (plumbing department). The original handle has a curve to fit the lit, so I used a wood rasp to put a little curve on the bottom of the knob. Then I put the rubber washer under the knob and tightened the screw snugly. That was nearly two years ago and it's still going. So if you can't find the exact knob you can try rolling your own.
Jan 23, 2011 | Rival SCE500 5-Quart Slow Cooker
I have a new mini jet book and trying to download ebooks having difficutly Pls help
Hi, to download books you have to make sure they are in TXT of FB2 format. First check the format of the book you are trying do download. If it is a different format you can easily convert it with Calibre converter. You can do a Google search for this eBook converter software.
After you have a book in this format move it from your PC to the jetBook using the cable provided. Or you can put it on an SD card and insert the card to the device.
Dec 20, 2010 | Ectaco jetBook
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
How do I acces the lid switch on my kenmore washer
The following link explains step-by-step how to access and/or replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Most lid switches are located under the right hand side of the top panel. Some, are located adjacent to either lid hinge. In any case, you still need to remove the washer exterior case to access it. The switch is held in place with a couple of mounting screws with a ground wire attached. This is a very simple repair, but if you experience any difficutlies please let me know. I hop this helps you.
Nov 27, 2009 | Kenmore 24032\24036 Top Load Washer
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
KIRBY G4 FAN ASSEMBLY ORDER
First put the gasket on the spacer, thin end to to out, push it down all the way on the motor shaft, then put the nylon washer on, then the fan, metal washer and then the pulley, just snug it, (don't tighten too much just beyond hand tightening). Put the casing, top and handle back on.
Feb 01, 2008 | Vacuums
Malber P21 Front Load Washer Logo
374 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
