Question about Dual Audio Players & Recorders
Hi, my dual 1214 turntable is only playing on one channel, can you advise how this can be fixed please?
Posted by coli1 on
David Dunn
    Brigadier General:
  • 8,546 Answers
Turn your amp off, unplug the phono connectors and reseat them, then remove the headshell and do the same. While you have the headshell off, examine the 4 little wires for crimps and breaks.
Posted on Apr 25, 2011
My Dual CS 430 turntable suddenly stopped playing - rest of equipment (radio, CD player, tape deck) okay. Can you help, please?
Amplifiers always take the sound of the turntable via a separate pre-amp from all other systems, such as radio and CD players. This pre-amp can go faulty killing the sound from the turntable only. If the turntable goes through the actions of playing the record, then this is the cause of your trouble.
Sep 20, 2016 | Audio Players & Recorders
Sharp r-1214 turntable problem
The turntable motor is starting seize, it will reach a point and stop working. The only option is to replace it.
Apr 23, 2012 | Sharp R-1214 Microwave Oven
I have a Technics turntable Model: SL-BD22-KM, Ser.#: GF3Fc73813. The RCA and ground connection panel on the turntable has been jurked-out tearing the wires apart. I need to know which wires are soldered...
hi,
Here is the wiring of the turntable RCA plug ( RCA wire will have 4 connections like red and its outer wire then White and its outer wire.). connect these as follows.
For right channel
Red wire from the turntable to the red center wire of the RCA plug
Green wire from the turntable to the outer wire with red wire of the RCA plug
For left channel
White wire from the turntable to the white center wire of the RCA plug
Blue wire from the turntable to the outer wire with White wire of the RCA plug
OK
Oct 10, 2011 | Technics SL-BD22 Turntable
Technics 1210's playing out of one speaker / channel
Have you considered the amp to be the problem? The amp has a magnetic cartridge pre-amp, which only the turntables would use, that can fail. It's often a single IC that has gone.
May 13, 2010 | Technics SL-1210 Turntable
Record only plays through one speaker
If it works on Channel One it is NOT the TT. It's a mixer problem. Define the mixer and what else works or doen't work. have you tried another device on Channel 2?
Apr 30, 2010 | Technics SL-1200MK2 Turntable
DDr or Dual Channel Ddr
From the manual:
2 x 184 pin DDR DIMM Sockets support up to maximum 2 GB unbuffered PC 2700/2100/1600 non-ECC DDR SDRAM memory.
So, to answer your question, for your particular motherboard, no. However, to dispute the other poster, Dual channel is better than regular DDR. It's just your motherboard does not support it.
Jul 03, 2008 | ASUS A7V400-MX Motherboard
Cdj 800
CD reader sounds like it's stuck. You might have some debris inside, or the reader might need to be replaced. Not an easy fix, and I would suggest contacting a service center for assistance.
DJPROAUDIO
TWEAK AV LAB
Jan 13, 2008 | Pioneer CDJ-800 Turntable
174 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
