Master
- Posted on Apr 25, 2011
Re: Hi my Samsung R530 will not turn on. I have the...
Hi danielgardha,
I see that you are experiencing issues with your Laptop, you mentioned that the battery has %40 charge and that the adapter is plugged in on the laptop to the wall but still you get an orange light, but when you press the power button nothing happens on the machine.
- Remove the battery and the adapter from the Laptop then press and hold down the power button, this is to drain power from the motherboard.
- Once the power has been drained from the Laptop, connect the adapter back again but leave the battery out of the machine, then turn the system ON using the Adapter only.
- If the Laptop turns ON using the adapter only then it is possible something is wrong with either the Battery or the motherboard of the Laptop.
- Turn the Laptop OFF again then put the battery back in, then power the system again check if it will turn on with the battery and adapter in the Laptop.
- If the Laptop does not turn ON when the battery is plugged in then you will need to have the system checked for a motherboard issue.
I hope that this will help.
mvincentc
