MT 150/9 Hi, I've Tally MT150/9 S/N: 1702469 tied up with a Fire & Gas Systems. The problem started when we had an alarm where it printed out all the details as to what equipment were affected, etc. The head was stuck on the left side halfway of doing its job. I've done the cold reboot (and a number of system resets) on the F&G panel and also power cycled the printer but still the problem was not rectified. I've cleaned the printer head area but got the same result.
Posted by mhel_sernio on
5 Related Answers
Anonymous
  • 47 Answers
SOURCE: Flashing Lights on HP 690C - Won't Print
Hi Stev, First I know this is going to sound strange but have you disconnected the printer cable from the printer itself? (not the computer) If not try unplugging both the parallel and power cables for 30 seconds, then when you reconnect and power up hit the resume button. I've seen problems in the past where a job was killed like that and the printer would not work until the parallel cable was removed from the printer. The light pattern you describe, resume light blinking with the power light on, can mean any one of the following things on that model HP. 1. Top cover is open. Open the top and make sure there is nothing keeping the cover from closing all the way. Don't forget to check the underside of the cover for something stuck to it. Close the top cover. 2. A print cartridge is missing or an incorrect print cartridge is installed. Install the correct print cartridge. AND/OR Verify that the print cartridge is properly snapped into place. Close the top cover. 3. Printer detects an out-of-media condition. Load media in the lower (IN) tray and press the Resume button. 4. Media is improperly loaded. Remove media from the IN tray, re-square the stack, and reload. Make sure that the media-width adjuster and media-length adjuster are against the stack of media. Make sure that media is not buckled in the IN tray. Verify that the media-width adjuster is along the left edge of the tray and is pushing the right edge of the media against the right wall. 5. The printer timed out waiting for a form-feed command. Press the Resume button. The page will eject from the upper (OUT) tray. 6. Printer detects out-of-ink condition. Replace the print cartridge and press the Resume button. 7. Dirty Cartridge Contacts Use a clean foam-rubber swab or lint-free cloth slightly dampened with water. (Distilled water is recommended. Tap water might contain contaminates that could damage the cartridge.) Locate the copper-colored circuitry strip on the back of the cartridge. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. Unplug the power cord from the printer. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or lint-free cloth to remove the moisture from the contacts. If the carriage contacts show noticeable damage, contact the HP Customer Support Center listed in the printer's User's Guide. Plug the printer back in and try printing again. 8. Printer detects paper in the paper path. Turn the printer off and open the top cover. Make sure that paper is not jammed in the printer. Lift the right black rectangular paper sensor (located in the middle of the printer just below the silver rod on which the cartridge carriage slides) and make sure that nothing is stuck under the paper sensor, perhaps by blowing under the sensor. Close the top cover and turn the printer on. Try printing again. If none of this helps let me know and I'll see what else I can dig up on the problem. El Duderino
Posted on Nov 17, 2006
Jacci Spencer
SOURCE: cartridges not moving
replaced cartridge but keeps saying no cartridge what do i do
Posted on Feb 16, 2007
Anonymous
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
Anonymous
  • 180 Answers
SOURCE: Print job stuck and can not be deleted
click on this link http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=mp-56143-2&jumpid=reg_R1002_USEN
Posted on Oct 22, 2008
Anonymous
SOURCE: blinking amber light will feed labels but doesn't print on them
I have had the same problem and just got my printer working. I moved the peel lever to the lower postion and the printer now works without any problem. The user guide says to postion the lever to the up position (inactive) but that caused the amber blinking lights (not recognizing the label properly)when loading labels. Hope this helps
Posted on Aug 11, 2009
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
I have prolem with fire alarm system
I need more information to answer this question, sounds like you might have a ground fault. These are headaches to troubleshoot and it would be best to get a technician on-site to resolve.
Jan 30, 2014 | Sony Home Security
Print Preview before Printing
Select Your printer as default printer and then see print preview of your document from your File menu
Oct 11, 2012 | Tally MT661 Printer
I have tally erp 9 ... i want to print some doc of tally but it is not print.... ordinary other doc are printed ... i am not understood the problem... pls help me...
Dear Raju.
Please open the Tally software & visit the help option & in the same please read how to print the document.....]
Ok
thanks
Dhiren Motivaras
Sep 16, 2011 | Computers & Internet
TALLY 2250 HARDWERE ALARM WITH 0000000002 -2032
Hi, the printer seems to have a problem with the horizontal movement of the print head carriage. Turn of the printer and move the carriage by hand to check if there is an area where it can only be moved too hard. If yes, clean the carriage shaft from dirt, etc.
Sep 04, 2010 | Tally T2250 Matrix Printer
When we give print command from tally software computer hang
The problem is related with the Papersize in Windows and PaperSize in Tally.
Usually your selected PaperSize in Tally and the LeftMargin.
Just adjust both (by pressing F12 function key, just before printing).
Please try the following steps, in sequence:
1. Select the printer, just before starting the printing.
2. Select the desired PAPER SIZE and return to Tally.
3. In Tally, press F12 function key and select the desired width and height of the paper, and also the Left Margin.
This will solve the problem.
Jun 25, 2009 | Computers & Internet
Tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Dec 07, 2008 | Tally T2250 Matrix Printer
Printhead hot error on tally t2265 but all pins fire ok, just stops and gives error, printhead is cool to touch, after a few minutes it prints a line or two again. it does this immediately, not after a...
The problem is with the main board when it gets print head hot immediately. The power supply is still functional, but something on the main pcb portion causes it to give an immediate "Print Head Hot" alarm
Jul 22, 2008 | Office Equipment & Supplies
90 people viewed this question
Ekse
Marvin
Marvin
