LG LCD TV 42LG5010 Remote control
Cannot find a Sky+ Remote Control Code for an LG 42LG5010
Sky+ Controller is a Rev:6
Codes tried so far are:
0065, 0206, 0584, 0726, 0742, 0743, 0244, 0405, 0318, 0037, 0398, 0919, 0459, 0254, 0137, 0634, 0389, 0275, 0502, 1293, 0851, 0857, 0136, 0508, 0672,
it is of note any numbr starting with 1**** does not regiter as loaded into the handset i.e. double flash.
Any Idas on which number to use or do I need a new Remote controller Rev:8
Posted by MMJy on
  • lee bexton Sep 13, 2008
    Ive the same problem
  • mrtnrowell Nov 01, 2008
    i have the same problem but my remote is rev 8. did you get a code in the end?
5 Related Answers
Anonymous
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central 2. Settings
3. Remote Control 4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
Posted on Mar 11, 2008
Anonymous
  • 124 Answers
SOURCE: Need TV codes for programming a remote control
Here.
LG TV codes: 0178, 1265
Posted on Apr 09, 2008
Anonymous
SOURCE: LG 42LC2S - Remote control code
After many months trying to find the BT Vision code for my LG 32LC2D, i have just had success with 005 remembering to enter an additional zero after the remote has flashed three times, so you enter 0005.
Hope it works, good luck!
Posted on Jul 06, 2008
Anonymous
SOURCE: code for sky remote control for LG 42LT75 LCD TV
the remote i had was rev 6 control and i tried every number going but no luck.
i then ordered new remote control which is rev 8(you can find this when you open the battery lid)
and i typed in 0206 and it worked(bingo).
good luck
Posted on Sep 27, 2008
Anonymous
SOURCE: need code for viewpia 32" tv for sky remote control
VIEWPIA
LC-321EF4
SKY Rev 8
0904
Posted on Oct 22, 2008
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I have just purchased an LG32lcd 450 tv, I cannot get the handset on Sky to work as they do not have a code to do this as the tv is new to the market, can you please help with this
OK, as you already discovered there is no specific code for your remote. You can try the generic codes for LG which I've listed below. Your TV may use the same flash patterns as some other older LG TVs so these codes might work.
Try these codes but if they don't work it's unlikely your remote will work with your TV - you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due - which will hopefully contain a specific code/flash pattern for your TV - but I've not been able to confirm this yet.
Nov 23, 2010 | LG Televison & Video
Sky remote code for lg television model no.32pg6000 to programe remote controll on sky remote
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | LG L3200AK Television
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
42LH3000 I CANT GET MY SKY REMOTE TO WORK WITH THIS TV. I NEED A CODE IF THERE IS ONE
Once you have the ver 8 controller - code 1176 should work
Code for sky+remote control for lg tv 50pc56
Haing same problem. Think it's the version of the remote control unit you have. If you have Rev 8 (it tells you inside the back cover) then some codes should work, if rev 6 or rev 4 it can be tricky. Try the following, but can't guarantee anything:
0742 0743 1962 0065 0405 0318 0275 0037 0391 0137 0459 0389 0398 0191 0244 0502 0245 0584 0311 0634 0072 0246 0060 0206 0065 0743
Feb 08, 2008 | Televison & Video
Sky remote codes
With an up-to-date remote (rev 8 remote) the 4-digit code 1280 definately works for the LG 32LC56 model coz i have just done it.
Jan 22, 2008 | Televison & Video
Televison & Video Logo
647 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
