Question about Razor E100 Electric Scooters Red
Razor E-100 - The toggle switch was broken, I replaced it with another lighted switch, but the switch won't light. The motor runs o.k., why won't the switch light when turned on? Thanks.
Clif Roberts
    Habit-Forming:
    Scholar:
  • 89 Answers
The Switch can be almost any but the lighted switch has to be a compatible 24vdc lighted switch.
As seen on this web page.
SWT-105
Razor E100 and E125 Electric Scooter Parts ElectricScooterParts com
Posted on Feb 13, 2015
Have a 97 honda. Just purchased. It has a toggle switch installed that works with original key ignition. That said... toggle controls whole electrical..everything works..except tail lights,and the dash...
So If I understand, you turn on toggle and then use key to engage starter? Do brake lights and turn lights work, just not the running lights? Or are all tail lights dead. If none work, juice is not getting to the headlamp switch. Best fix would be to replace the probably bad ignition switch and repair wiring back to original, but quick fix would be to run a second wire from toggle switched side to the headlamp switch +
Dec 18, 2014 | Cars & Trucks
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
Light Switch Won't Work, How do i fix it?
Sounds like the switch its self is broken REPLACE IT make sure serciut breaker is off first
Jul 08, 2013 | Electrical Supplies
Passenger window won't go up or down
open the door interior light will be on put the vehicle ignition in run postion dash lights will be on operate the window switch up and down look at dome light if it is dimming a little when operating switch window motor is no good if not remove the switch and check power at switch if none the boot between the body and door has a broken wire
Aug 09, 2012 | 2000 Plymouth Voyager
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
I have a 94 ford probe, The radio works when it wants to.. but the prblem is the tail lights and dash lights went out about a week ago, Checked all fuses in car and under hood checked all light bulbs all...
You need to replace headlight switch - if fuses, bulbs, wiring looks good. Avoid the toggle switch idea, you'll be opening a whole new can of worms.
Mar 01, 2011 | 1994 Ford Probe
Rear brake lights not working
first check your fueses, if thats not it on the slinder part of the arm behind the dash "the break" arm. There is a toggel switch when you push the break the button will release causing the break lights to come on when you let off the breaks it will engage the toggle switch and turn off the break lights....if the toggle switch goes out they wont work also have some one stand behind the car and wiggle the wires of the toggle switch see if it has a bad connection before you replace the switch could be just corresion or the wires may have came loose..
Dec 22, 2010 | 1994 Geo Prizm
Driver side window not working
I assume that all the other windows are working. This means there a problem with the driver window switch or a problem with the window motor and regulator. Remove the interior door panel. Check that the regulator is not broken or jammed. Then test with a voltmeter to see if there is voltage at the window motor when the switch is toggled. If there is voltage, but the motor does not run, you need to replace the motor. If there is no voltage when the switch is toggled, chances are the switch is bad and needs to be replaced, although there could also be a problem elsewhere in that window circuit.
Mar 19, 2010 | 1993 Subaru Legacy
Razor E100 Electric Scooters Red Logo
184 people viewed this question
Top Razor Sport & Outdoor - Others Experts
Randy Schumann
Randy Schumann
Tom Chichester
lazarodelapaz
Are you a Razor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
