Konica Minolta DiMAGE A1 Digital Camera Logo
Posted on Apr 25, 2011
The external battery pack kit EPB-100 for my Minolta Dimage 7i appears to be out of manufacture at retail an internet outlets I have tried. Any ideas where I can obtain one or other compatible battery pack kits from from please?
4 Related Answers
A
Anonymous
  • Posted on Jan 19, 2008
SOURCE: minolta dimage 7i fix
I just found a solution to my camera problem. It turned out to be the batteries. We purchases some Rechargable Duracel with a 2650mAh rating. After charging the batteries I put them in the camera and it started right up and was taking photos like when we first bought it. I have not been able to use the camera in almost 2 years and it turns out the problem was weak batteries.
So anyone that has a Minolta Dimage 7i and cant get it to turn on make sure you have at least 2650mAh rated rechargable batteries. The higher the mAh rating the better.
Hope this helps someone else. We are ecstatic that we can use our camera again. No more using my camera phone!!!
t00nz
CameraR
  • 4738 Answers
  • Posted on Nov 17, 2007
SOURCE: minolta dimage 7i powers up all functions but lcd and viewfinder are blank
You both are in luck. This sounds like a defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
A
Anonymous
SOURCE: Konica Minolta DiMAGE 7i Digital Camera Problem
A
Anonymous
  • Posted on Oct 04, 2008
SOURCE: KONICA MINOLTA DiMAGE 7i COMPATIBLE COMPACT FLASH CARD
go to www.memorysuppliers.com order the below item
1 SDCFB-1024-A10 - SanDisk 1GB / 1024MB Compact Flash card
1helpful
I need an external flash for my Minolta Dimage 7i
Having researched the internet - I've found a Minolta branded flashgun suitable for your camera. It has the bounce flash you ask for, however it's not cheap.
Here's the link:
http://www.crazycameras.co.uk/index.php?act=viewProd&productId=9097&aff_code=gg
2answers
Focus problems
go to the Konica Minolta customer technical support[now part of Sony] However I doubt an item of this age is repairable due to lack of parts.
External power battery pack
No. The EBP-100 is not usable, and we cannot guarantee compatibility with any other manufacturer's external battery packs.
2answers
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
What is the external battery pack "EBP-100"?
This is the external battery pack used for the DiMAGE A1, 7, 7i,7Hi, 5, S414, S404, S304, Z1, Z2 and A2. This is the type of external battery pack that connects the camera and the battery part with a cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Two lithium batteries NP-100 Approx. 480 frames(recording), Approx.450 min(playback) Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Battery Charger BC100 is sold separately. INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
1helpful
What is external battery pack "EBP-100"?
This is the external battery pack for DiMAGE 7, 7i,7Hi, 5, S414, S404 and S304. This is the type of external battery pack to connect the camera and the battery part with cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Battery:Two lithium batteries NP-100 Battery performance: Approx. 580 frames(recording), Approx. 580 min(playback) Accessories: Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Optional: Battery Charger BC100 is sold separately. BC-100 specifications: INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
