Question about Vulcan Heating & Cooling
Hi - I have a very old Vulcan gas heater - it must be at least 20-30 yrs old. The pilot light has gone out and the flint (?) is not sparking when I push the ignite button. Is there a way to open the heater out from the wall to look at the inside and or replace the flint? The heater has fake wood around the edges, a wire grill and a glass shield inside made up of segments of glass. It has a two speed fan but no model number can be seen. The word Vulcan is on the bottom right corner. Thanks
Posted by julie_hutley on
3 Related Answers
Anonymous
  • 30 Answers
SOURCE: Rinnai wall heater won't lite.
You may need to take the pilot assembly apart and clean the pilot orifice. If the pilot does not stay lite you may need a new thermocouple. Good Luck.
Posted on Mar 29, 2008
David Shaub
  • 2976 Answers
SOURCE: The pilot light has gone out on an old Vulcan gas
You probably need to replace the thermocouple before you will be able to get it lit.
Posted on Oct 14, 2009
Sulaiman Sarumi
  • 586 Answers
SOURCE: Hi, I have a vulcan
When the fan of your heater does not turn on and the igniter lights but then goes off, then it means there is a problem with the unit of the machine.
The problem with the furnace is that the element of the furnace is bad and need to be replaced. Also check the relay switch of the furnace, that way you will be able to fix both the fans problem and the ignitors also.
Hope this was helpful to you.
Goodluck
Elect_Comp
Posted on Jul 04, 2011
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Vulcan express gas continuous flow/model # 230010N0/serial # 66669/ Date 19-08-98. I can hear and smell gas when trying to ignite the pilot light and the igniter spark, "sparks", but pilot light...
VULCAN water heater continnous model number 23001ono. im looking for a brass nut that sits on with a very small hole, with a number on it (25)
Mar 10, 2011 | Heating & Cooling
Describe your Problem i have a quasar vulcan gas heater pilot light is on but wont ignite. can hear it clicking trying to ignite what is the o=problem . this heater maybe about 20 years old
What do you mean by the pilot light is on but won't light. Do you mean that there is gasbut won't light. If so the spark may not be hitting the pilot properly or it may not be getting enough gas. If lighting but continuing to spark the sensor may need cleaning. This can be cleaned with steel wool (not sand paper), probably will need to disassemble the pilot asembly The pilot may also be dirty reducing gas flow. If this is the case dis-assembly will be needed and the pilot cleaned.
Sep 05, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Have a 20yr + old vulcan gas heater and I cannot turn pilot off
Hi, If you are talking about the knob on a gas valve that you use to light the pilot and turn it off also, you have to turn the knob either ccw or cw to turn it off. To light the pilot is when you turn the knob to pilot and push down and hold it, light the pilot while you continue to push it down for a minute, and then slowly release it and pilot will stay lite. So, if this is the type you have just turn knob one way or the other and it will shut off. If you do not have this type set up, just turn off the gas to the furnace at the flex line as there should be a hand valve by code and by law that supplys gas to you're furnace. You can shut it off there and the pilot will also shut off.
Sincerely,
Shastalaker7
PS If you don't have either one of these shut off's, on the main gas valve it self, you should have a place marked pilot adjustment. Pop the small chrome cap and insert a very small screw driver to turn it cw to shut off pilot.This would be you're last choice.
Jan 19, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
The pilot light has gone out on an old Vulcan gas wall heater. How do I turn it back on?
Oct 14, 2009 | Vulcan Heating & Cooling
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
