these means that you have problem with scanning lamp or scanning section.
Open the document cover and turn ON the copier, see if the lamp will glow, if not, probably you need to change the scanning lamp, but if it glows and you still has the E220, remove copy glass and put the scanning lamp in home position ( to the left side ) - NORMALLY BEFORE REMOVING THE LAMP TURN THE COPIER OFF AND PULL THE POWER PLUG FROM THE POWER OUTLET!!!!!
Hope that helps!
