Maytag 24" Built-In Single Electric Wall Oven - White Logo
Posted on Apr 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My oven display has "sABBATH" written on the
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Apr 24, 2011
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3073068
Points
27242
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
GE Dualfuel slide in Serial #C2S995SEL2SS
This means that the Sabbath mode has been enabled. To disable the program, first press and release the Cancel/Off to stop the current programmed bake settings. Then press and hold Settings until Sabbath Mode Off is displayed. See page 14 of the manual for setting the Sabbath mode. The manual is available on the product page: https://www.geapplianceparts.com/store/parts/assembly/C2S995SEL1SS . The current link to the manual is https://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85241.pdf . Most GE oven codes are listed here: https://www.geappliances.ca/en/support/knowledgebase/range-oven-function-error-or-fault-codes . The Sabbath Mode symbol is shown at the bottom of the table.
This mode can be used to set the oven temperature for an extended bake (usually for a low temperature) or a programmed bake. It's used by those who strictly keep the Sabbath but want a hot meal ready when the Sabbath ends.
I hope this helps.
Oct 06, 2019 • GE Ovens
Tappan built in oven display not working
Find the owners manual and check to see if it has a sabbath day mode if not you will need a oven control which has the display assembly
The display says "SAB" on
it's locked in sabbath mode for jewish holidays,hold the clock pad in for 3 to 5 seconds to take it out
Sep 18, 2011 • Ovens
2answers
What does 5ab mean on the oven?
Some ranges with a lot of features have a Sabbath mode, hence the letters Sab in the display although it looks like 5ab. Check your owners manual and it should tell you how to turn off the Sabbath mode. If you don't have a manual Google your model number and Sabbath mode.
Aug 28, 2011 • Ovens
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I can not use the oven. I got a display " sabbath", but the key path are inactive. What can I do.?
The oven is in sabbath mode which wont let you do anything, unplugg it for 1/2 hour or flip off the breaker for a 1/2 hour. This should reset it for ya!
Nov 09, 2010 • Ovens
Jenn-Air gas wall oven some how got stuck in ''Sabbath'' mode and unable to reset.
ok it happens / so to enable the Sabbath mode 1 open the door. 2 press cancel/off. 3 press the number pads 7&8 and 9 , in that order. 4 press Number pad 6 . 5 press start. "sab and on" will appear on the display ..( now to disable the sabbath mode .}. ( repeat the steps above to disable the Sabbath mode. " Sab and off" will appear on the display .. there now that wasn't too tuff was it .. mm hope this helped ..
6helpful
Readout is stuck on 5Ab. Can't do anything with it
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
