Food Processors Logo
Posted on Apr 24, 2011
Fp25001kt I cannot figure out how to get the wide mouth assembly to work. It seems like the safety only works if the small mouth is used? I would like to use only the wide mouth for larger vegtables. There seems to be a longer part that is not attached in the middle that is useless?
When the new processor is plugged in, the motor does not work
Denise suspect all items below not locked in to place
have you locked in the work bowl ?
have you locked in the lid ?
have you locked in mouth feed chute ?
For your protection this appliance has an interlock system. The processor will not operate unless the workbowl, cover and wide-mouth feed chute are properly locked in place.
see page 6 and 7 of user manual
http://cdn.spectrumbrands.com/~/media/SmallAppliancesUS/Black%20and%20Decker/Files/FP2500%20Use%20and%20Care%20Manual.ashx
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Hi there, my dough blade won't come out from my fp2500mc wide-mouth food processor. Is there's anything that I can do. I've tried everything but it won't come out
i have had this same problem and unfortunately it seems that the disc stem gets so hot that it melts the top of the bowl to the blade. I finally got it out but the bowl was ruined as was the dough blade.
5helpful
Unit assembled, lights are on (pulse, on) nothing happens
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
5helpful
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
11helpful
3answers
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
I feel so stupid i can't figure out how to get the food out of my rrkfp650 kitchenaid mixer! help my kale is getting stale. why doesn't it just slide off or twist off?
Most recent food processors have safety features that make it difficult to remove the work bowl. For the Kitchen-Aid RRKFP650, remove the work bowl pusher and cover first. Then you have to give the work bowl a good tug in the clockwise direction - don't be afraid of breaking the work bowl - it can take a little bit of force. If it is still sticking, you can apply a small amount of distilled white vinegar with a Q-Tip to the area between the base and workbowl - in most cases, you won't have to do this.
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Have trouble getting it to start
Top Black & Decker Food Processors Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
