The most common caused why your unit didn't power up was because of faulty power supply board. Since you've already checked the AC line, the fault now is quite technical if you haven't an experienced in electronics. The board must check the faulty parts like the fusible resistor in line with the shorted voltage regulator IC/transistor (mounted in heat sink), dried electrolytic filter capacitor, open/shorted chopper transformer, shorted diode. You must know how to test this parts to pinpoint where the fault came from. If you can't troubleshoot the board yourself, you may replaced it by inquiring to your local pioneer service center for the power supply board's availability.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
