I have aProview Pl926Wbi monitor flat screen, when I turn it on the power light comes on and stay on I will see it starting up on the screen then while the power light is still on the screen will go black I will then turn the monitor off and then back on I will see what is on the screen for about 5 sec then it will go black Then I start all over again . While the screen is black I look at it real close and I can see a image of my wallpaper on it like it is on but there is no lights to show it.
Posted by Msnowsr on
5 Related Answers
map9966
Mike Peluso
  • 2351 Answers
SOURCE: pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Posted on Dec 21, 2007
Rishi Roshan Ali
  • 2427 Answers
SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Posted on Jan 12, 2008
edisonfrelan
edison capulso
  • 113 Answers
SOURCE: Monitor displays breifly then goes to blank screen
try booting up your CPU again, while on its process of booting press F8, then select (something MODE), okay, then when you are at windows environment go to control panel, select display, set your display settings its default or 900 by 600 pixels settings, then if its run okay then change to your desired settings.
Posted on Dec 17, 2008
Starfish Phoenix
  • 73 Answers
SOURCE: screen comes on for a second then keeps going black, if I turn monitor on and off it will come on but then goes right back off again
Broken powerboard/inverter in the screen presuming its an LCD. Can be costly to fix
Posted on Apr 21, 2009
Anonymous
SOURCE: Samsung 940BX LCD monitor 9
The IPboard part no. BN44-0012A is bad. We had to replace 5 monitors with the same problem. If under warranty call 1-800-Samsung for repair or exchange.
Korhan Balimtas
Posted on Apr 23, 2009
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
Monitor only stays on a few seconds
You have a burned out Backlight Fluorescent Bulb.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19# model PL926Wbi
thers Sounds like the problem I'm having /had exactly. When I opened the case I found that like others the 470mf capacitors on the power board had gone bad. (See the post from Delphiuser)
The capacitors are probably from a Chinese company called Xandu and I'm currently looking for a replacement capacitor to fit the circuit. Its a 470 mf cap with a 25 volt rating .
May 01, 2008 | Proview PL926WBi 19" LCD Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi LCD Monitor White Screen
I found in the refuse, a Gateway FPD 1520, 15" LCD monitor that started off losing the screen half-way, losing sync, etc. The "mechanical agitation" method was applied and remedied the problem. Awhile ago, it went to a white screen (or, as it was back in the day- a clean raster). I opened it up and found that the ribbon cable on the left was loose. I applied a series of layers of adhesive-backed foam (the kind you stop drafts in your home with) until it was greater than the height of the metal enclosure to put pressure on the unbehaving connector. It does seem a bit loose and this will keep it snug. Maybe hot glue or other adhesive if it wiggles loose again. Seems to have solved the problem at the moment.
Oct 15, 2007 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
26 people viewed this question
Ekse
Marvin
Marvin
