Question about Braun Thermoscan Pro 4000 Ear Thermometer
How do I change my Braun ear thermometer back to F from C
Posted by pjkolb13 on
Lance Hill
    Genius:
  • 1,739 Answers
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
Changing the temperature scale
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Posted on Apr 25, 2011
How do you change batterie in thermoscam ear meter
on the side with the screen about 3/4 of the way to the bottom should be a tiny hole put a pen in it and push down to release the lock and open
Apr 07, 2013 | Braun IRT3020 Thermoscan Ear Thermometer
What is the flashing horn signal on braun thermoscan
It looks like a horn it is actually a picture of the thin plastic cover that goes over the end before you put it inside the ear. Put the cover on and it will work.
Sep 25, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
4 year old braun thermoscan IRT4520 having some problems
is the drawer that its stored in, in the bathroom? the humidity or moisture could affect it. I have had mine for 8 yrs and works perfectly. Are you placing the probe covers on correctly and waiting for it to click or a pop before inserting into ur ear.?
Jul 03, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
I don't have the directions how do I work it i have ThermoScan and want to use on 4month old
How to use Braun ThermoScan 1. Always make sure a new, clean lens filter is in place to help ensure an accurate reading. The thermometer will not function without a lens filter attached (see Changing the lens filter). 2. Press the /mem button. The LCD (liquid crystal display) is activated, showing all segments. When the ready symbol is displayed the thermometer is ready for use. 6 To help ensure an accurate temperature reading, use the following technique: If you are right handed, hold the thermometer in the right hand and take the temperature in the right ear. If you are left handed, hold it in the left hand and use the left ear. 3. Perform an ear tug to straighten the ear canal. This gives the thermometer a clear view of the eardrum. Children under 1 year: Pull the ear straight back. Children aged 1 year to adult: Pull the ear up and back. An ear tug is best performed by using your free hand to grasp the outer edge of the top half of the ear. To take your own temperature, wrap your free hand around the back of your head and grab your ear from behind. 4. While tugging the ear, fit the probe snugly into the ear canal as far as possible and press the activation button. Release it when you hear a beep. This is the Temp Beep that confirms the end of measurement. 5. Remove the thermometer from the ear canal. The LCD displays the temperature measured. 6. Replace the lens filter after each measurement: press the ejector button and put on a new, clean lens filter. 7. A new measurement can be taken as long as the ready symbol is shown. If no button is pressed within 2 minutes, the thermometer will turn off automatically. 7 Note: In the following situations, it is recommended that you take three temperatures in the same ear. If they differ, use the highest reading. · Infants in the first 90 days of life. · Children under three years of age who have a condition such as a compromised immune system and for whom the presence or absence of fever is critical. · When you are first learning to use the ear thermometer until you are comfortable with the technique and are obtaining consistent readings. Important: As with any type of thermometer, slight temperature variations ( ± 0.3 - 0.5 °F / ± 0.2 - 0.3 °C) can occur, if consecutive measurements are taken. Temperature taking hints · The right ear reading may differ from the reading taken at the left ear. Therefore, always take the temperature in the same ear. · The ear must be free from obstructions or excess earwax buildup to take an accurate reading. · External factors may influence ear temperatures, including when an individual has: - been lying on one ear or the other - had their ears covered - been exposed to very hot or very cold temperatures, or - been recently swimming or bathing. In these cases, remove the individual from the situation and wait 20 minutes prior to taking a temperature.
Mar 04, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How to change thermo from C to F
Here is a link to the manual. Follow directions on page 10.
http://braun.kaz.com/files/IRT3020GB,%20F,%20E%20%28USA,%20CDN,%20MEX%29.pdf
Feb 25, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Braun Thermoscan Pro 4000 Ear Thermometer Logo
3,804 people viewed this question
Top Braun Home Experts
john h
Tom Chichester
Are you a Braun Home Expert? Answer questions, earn points and help others
