Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Fan is making a loud noise. When I open the door, the fan stops.
D. Floyd Kolb
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Posted on Apr 24, 2011
My freezer door was left open. food partially thawed, motor making a loud clattering sound. after shutting the door, the noise stopped. it took>24 hrs for the food to refreeze
Maybe evaporator fan making noise. After leaving open for long time, there was probably significant frost build up on evaporator near fan.
Oct 06, 2018 | Refrigerators
Freezer fan making loud noise
it may not be defrosting and the ice has built up to the fan and you are then hearing noises, you need to have it checked
Dec 19, 2017 | Refrigerators
The freezer is making a loud buzz sound that stops when I open the door.
Could be the evaporator fan motor about to fail or the evap fan blade touching something. If the fan is controlled by a door switch, opening the door would deactivate the motor and the noise would stop. Depress the door switch and see if you can locate the exact source of the noise.
Mar 03, 2010 | GE Refrigerators
Some fan making a loud noise. When open either
It sounds like it is probably your evaporator fan, seeing as that fan will cycle off when the door is open, and resume when you close the door. Either some how something got in to it, or it is going bad. Hope this helps
Oct 07, 2009 | Refrigerators
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
My computer makes a loud noise in the fan
The drive door issue may indicate a virus infection. As to the fan, you would have it replaced. If not under warranty open the case and track which fan the noise is coming from
Mar 25, 2009 | E-Machines eMachines Desktop PC
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
598 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
