Marantz PMD660 Digital Voice Recorder Logo
A
Anonymous Posted on Apr 23, 2011
Pmd660 dislay too dim to read - Marantz PMD660 Digital Voice Recorder
My Phillips 47pfl7603d/10 is dislays a dimmed screen and sometimes a flipped negative image on the right side. This happens 2m-40mins after turning on. Contrast=60 brightness=0 Colour=60
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Can't get rid of background noise on my marantz pmd660
Did you ever find a solution to this problem? I have tried new AC adapter cord and it still has background noise. The only time it doesn't is with the batteries.
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
"completed" remains on display
I solved this problem be removing the batteries briefly so that I was able to start again with a clean slate.
Marantz PMD 660 won't power up from batteries
I would suspect the battery tray connections are defective most likely due to a broken wire.
3answers
Marantz PMD660 Headphone Jack inside machine
take out the pins that resemble watch pins! remove the stickey label with the
power switch,usb and 5 volt jack cut outs! If you have taken out the screws needed up to this point and you are a little bit technical this should get you into the unit.
If you don't have the skill, hire it out. Joe Taken
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
