Cameras Logo
Posted on Sep 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After using my Panasonic Lumix DMC-TS2 in the ocean, my front buttons, including display, delete (/quick view), playback, video record, and all the centre buttons do not work. I can't press any of them, along with my zoom. The on/off usually works, same as my shutter button. It is supposed to be waterproof ( including saltwater) and drop proof, and other stuff.
Tony Parsons
Level 3:
  • Panasonic Master 6,405 Answers
  • Posted on Sep 22, 2017
Tony Parsons
Panasonic Master
Level 3:
Answers
6405
Questions
Helped
1652237
Points
20272
Since Amazon has them for about $60, I should just replace it - repair will cost more.
5 Related Answers
Anonymous
  • Posted on Oct 13, 2008
SOURCE: Video playback problem on lumix dmc tz3
I don't have a solution to the first part of your dilemma (why it won't playback) but I do have a solution for deleting the file.  On your camera are "hidden" file folders.  When you connect your camera to your computer, you probably only see two folders (that's all I see for my DMC-LZ8).  But there are more, and your undeletable picture/video is in one of these folders.  Find the folder and you'll find the file.  Delete it from your camera using the computer to do the command.  Problem solved.  Okay, so how do you find the hidden folders?  I have a Mac, so my process was this:  1) Connect camera to computer; 2) Select/open camera icon (looks like "volume disk"); 3) From top Finder bar, select File then Find;  4) Select the camera volume to limit your search to the camera (not HD or other external hard drives you may have connected to your computer); 5) Select "Kind" and in the next dropdown button "Folders".  Voila.  Happy searching.  My hidden "undeletable" video files were in a folder called "100_PANA".  I selected them then moved them to the Trash.  Be sure to eject your camera properly (don't just turn it off or disconnect it).
Good luck.  I hope this helps.
PS - My theory is that this occurred after an upload to my computer got unexpectedly disconnected before everything finished loading or else the camera got disconnected from the computer incorrectly even if the upload had already finished (see above comment to eject camera properly).  In either case, the blank/black screen, unviewable but "there" on the camera taking up memory photos/videos problem happened to me, too.  The above actions resolved it for me.
Anonymous
  • 11967 Answers
  • Posted on Aug 23, 2009
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Anonymous
  • 35 Answers
  • Posted on Jan 17, 2010
SOURCE: Panasonic lumix dmc-fz8 shutter button cracked
Hi dear, you can try to order the parts from Panasonic and do it yourself.
I strongly recommend you bring your camera to an authorized repair center to get it fix by them.Because it looks simple to open the camera but it's not.
mick mack
  • 86 Answers
  • Posted on Dec 05, 2011
SOURCE: On/Off Switch Doesn't work on Lumix DMC-FZ35
Unless you have the knowledge to dismantle and fix it, you need the services of a repairer. Sorry.
gopakumarg43
  • 76851 Answers
  • Posted on Feb 07, 2012
SOURCE: where can i get user instructions for a panasonic dmc lumix fp8 digital camera
Hello
Chek chese links.
retrevo.com
www.pdf-manual.com/user-manuals-owners-instruction-guides-panas
http://www.dataentryjobs.us/67948.html
If you feel any difficulty in downloading the same, send your emai ID to me by Fixya comment box. I've the user manual to your camera, in PDF format, and I'll send a copy of it to you by return mail. OK.
I have a Panasonic Lumix DMC L580 and it states that the memory is full. As i dont have a manual how do i delete what is held in the memory please cheers
Are you sure of the model number? I can't find anything about a Lumix DMC-L580. There is a Lumix DMC-LS80. Make sure that you save any pictures before deleting them. Also make sure to have fresh batteries or the camera connected to AC power. If the camera runs out of power, the process will not complete.
To delete pictures from the internal memory, slide the recording/playback switch down. (The switch to the upper left of the arrow keys on the back.) This puts the camera in Play Back Mode. Use the Up/Down arrows (if needed) to select normal playback mode and press Menu/Set (in the center of the arrow keys). The delete button is the one on the right side below the arrow keys. Use the left/right buttons to select a single picture. Press delete. Press the left arrow to highlight Yes. Then press Menu/Set to confirm deleting the image. To delete multiple pictures, use the down arrow to get to Multi Delete or All Delete (instead of the left arrow). Press Menu/Set.
For All Delete, you may see an option to choose All Delete or All Delete except (star). The star indicates Favorites. If needed, pick one, press Menu/Set. Use the left arrow to select Yes and press Menu/Set again.
For Multi delete, use the left and right arrows to navigate through the stored pictures. Press the down arrow to select an image to delete. When you have marked all of the pictures that you want to delete, press Delete again. Press the up arrow to select Yes and press Menu/Set to initiate deleting these pictures. (Note: if a picture is protected, pressing the down arrow will result in On icon blinking red.)
The manual for DMC-LS80 is available from Panasonic support here: https://www.panasonic.com/au/support/manual-download/imaging/lumix-cameras/dmc-ls80.html . The current link to the manual is https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English_02-vqt3-vqt9_other/DMC-LS80%20Operating%20Instructions.pdf . See page 20 for the section on selecting the mode. See page 35 for deleting pictures.
I hope this helps.
(if you have a memory card in the camera, you will need to do the delete steps in two steps. Delete all (or multi) pictures from the internal memory and the memory card separately.)
After using my Panasonic Lumix DMC-TS2 in the ocean, my front buttons, including display, delete (/quick view), playback, video record, and all the centre buttons do not work. I can't press any of them,...
waterproof to 30 feet only,you went deeper and salt water got in,call the company,https://www.dpreview.com/products/panasonic/compacts/panasonic_dmcts2
Photos displayed as black in playback mode on Panasonic TZ3
Were they shot with the TZ3 or in another camera or from a computer?
2answers
No sound in recording videos
Do you mean in your camera or on your computer. If on your computer Google K-Lite. Hear you can download the codec drivers to update your computer to view and hear the movies you record.
1helpful
Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
2answers
Can''t PLAY the videos I make back....
check to see if there is a certain setting it has to be on find the video that you recorded on you camera and then click ok or whatever button you have to press to play it.
How tu use video recording..
The picture that I posted shows a TZ3 mode dial. I added a blue arrow to point out an icon on the mode dial.
1. Turn the mode dial on the camera so this icon is selected.
2. Switch on the camera.
3. Aim the camera at your subject, press the shutter button halfway to focus, then press it fully to begin the video. (Just as you would take a picture.)
4. To stop taking video, press the shutter button fully again.
~When a video starts being taken, its current length will appear on the camera's LCD screen.
~Videos take up more space on the memory card than do pictures.
~If an SD memory card becomes full while recording, then the video will stop automatically.
~Videos can be played back on the camera's "PLAYBACK" mode. They can also be viewed on a TV or downloaded to a computer.
9helpful
2answers
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
