Question about HP PhotoSmart C4280 Laser Printer
My printer prints blurrey out of focus pictures. I download from my camera and print a few on photogaph paper. This happened once before and for reasons that evade me it cleared up and printed fine. Now, it's happened again. I've tried two new 75XL HP tricolor cartridges..........with no change or luck. Time for a new printer ? Thankyou for your help..............Jim
Posted by jimflitcraft on
Alejandro, III Luces
    New Friend:
  • 24 Answers
Before replacing this awesome printer try this steps first.
First check the paper you're using, load the paper with the printing side down.
In the program being used for printing, click File , and then click Print .
Make sure the appropriate printer is selected, and then click Preferences or Properties.
Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
Paper size : Make sure that this option matches the paper loaded in the product.
Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry.
Posted on Apr 24, 2011
How do I print photos from my cd using hp Photosmart plus?
Don't Connect the printer. First use the cd to install the software for your printer. in the software is a program called print photos or print pictures. After installing the software, connect the printer and switch it on. Start the software and a menus should guide you trough he straps to choose and print the pictures you want to print. Be aware you need to setup things once the program is running, like how big the pictures should be. Don't make them bigger than the paper you insert. Also what kind of paper you use, like plane paper, or photo paper, matte or glossy.
Mar 20, 2015 | HP Photosmart Plus All In One Printer b210
I cannot get an E-size plot to print properly. I have no trouble with plotting D-size drawings. What are the correct settings to use to print E-size sheets?
Printing high quality photos using an inkjet printer is not only possible, but affordable too. Top notch quality relies on a few factors: the right paper, the right ink and the right settings. Read on to find out how to print photos with an inkjet printer.
1.Use a good digital camera. For 4x6 and 8x10 prints, you will want a camera with at least two or three megapixels.
2.Buy photo paper. Spend the extra few dollars to get high-gloss photo paper that is designed for your printer.
3.Use photo ink. High quality photos take high quality ink. Do not use the same ink that you use for documents.
4.Optimize your settings. Select "File > Print" then click "Properties" and find the preferences or quality tab. Set the quality to the highest or choose a photo preset.
5.Edit photos on your computer. Import your photos from a CD or your digital camera. See your camera's manual to find out how.
6.Crop and resize. Cut out anything extra in the background that you do not want and resize the picture so it will fit on the page.
Sep 19, 2011 | Canon iPF700 InkJet Printer
Prints only top half of picture
Can you print anything from WORDPAD or MSPAINT or NOTEPAD? try printing a website. if it continues to do this, then it could be a paper sensor on the printer, and that means, a failed printer.
Aug 28, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Printer keeps processing - nothing happens - no print
Not really sure about Mac, but if this happens on a PC, I would first uninstall the printer (software-wise) then download the latest drivers and install.
May 27, 2009 | Konica Minolta magicolor 7450 Laser...
I haven't used my printer for some time and just started printing , but have experienced some problems. The picture is very blurrey
You might need to clean the heads.
To do that, (assuming you are using Windows)
load a sheet of A4 paper, open the Printer properties dialog box, click on the Maintenance tab and then click on the cleaning icon.
After that you shoul select the nozzle check. and see if the lines come all right.
Good luck.
Dec 14, 2008 | Canon i850 InkJet Photo Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Photosmart 2610xi Printing Problems
you might want to reinstall the latest and greatest driver from HERE uninstall your other printer and download the correct driver from HERE and install it on your system before you reconnect your printer... www.BigMoneyCentral.com
May 11, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Error B8e7b69c
I have had this issue happen to me when trying to print a photo from my windows picture program and from the window photo gallery program on Vista. I believe the problem is a compatibility issue with the windows Vista photo programs. I was able to print very well using another photo program. So i suggest printing from another photo program. My camera came with one that is pretty basic and good at fine tuning the pictures. I used the Canon zoombrower ex program and it printed all my pictures well. I think most digital cameras come with some type of photo editing program. You should try printing from it instead widows photo folders or windows photo gallery. Using my camera's photo software solved my issue well. try this out to see if it works for you. good luck
Mar 20, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Printer
Before I go into your solution I have to mention a few things first. Your printer software utility has multifunction printing capabilities. What I mean is you can print on thin paper , thick paper , and even glossy paper. I would go into your settings for your printer specifically for pictures or graphics and see what the paper thickness size is set for. Compair this to your setting for normal text printing and change your picture and graphics settings so it matches your text printing. I would also check on your printer some have a flip switch to set the printing head height. If it is selected low this could also cause scratching.
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
HP PhotoSmart C4280 Laser Printer Logo
189 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
