Question about Scubapro MK25/G250 Hp Regulator
Yearly maintenance.... when you take your reg set in for "yearly" maintenance, what is it the technician does exactly?
Posted by bvkon on
robert DIBBLE
    Master:
  • 448 Answers
Thay change all the seals weather there bad or not thay do it for safety reasons
Posted on Apr 24, 2011
2 yr old ecco sense UMC 117 unit flashes 38 beeps and wont give hot water
1) Copy following link for Rheem tankless troubleshoot, including ecosense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Probably needs new circuit board.
3) Product manual usually give list of required yearly maintenance.
Perform the maintenance, just like changing oil on car, and then service technician is familiar with your water heater and can count on your money each year around Christmas.
4) For independence, reliability, cost, and convenience, don't buy tankless water heater, or any other expensive/complicated water heater that requires yearly maintenance, and generally cannot be repaired by homeowner.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 04, 2013 | Rheem Tankless Water Heater Main Remote...
BLINKING C2 AND 11
Before calling service technician, copy following link for troubleshoot resources:
C2 11: failed ignition, clean combustion parts, low gas pressure, failed gas solenoid, failed gas control valve, loose wiring harness, sand carbon off igniter, etc
Tankless require monthy-to-yearly maintenance to avoid common error codes. The product manual recommends yearly service. Since Rheem does not post service manuals, you generally have to pay somebody to take apart and test the unit. The cost of this far outstrips expected savings from owning expensive water heater that requires lots of maintenance, yet is heavily promoted as the solution to water heater problems.
Never install tankless water heater is best way to avoid complications of expensive water heater that is maintenance heavy, hard to diagnose, expensive to fix, etc.
Never expose tankless to more than 11 grains hard water.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Aug 25, 2012 | Water Heaters
Pilot flame is not large enough to contact thermo couple
Before calling service technician, open following link for Bosch troubleshoot resources, including manuals and Bosch contact information:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Each gas water heater manual recommends yearly maintenance that includes cleaning the burner and combustion parts, which includes check of connections, sensors, venting, gas pressure and air filter, etc.
Yearly maintenance covers most common problems that cause tankless failure.
Jul 28, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
The eco 180 dv tankless water heater will not turn on unless you run the tub/shower and lavatory at the same time. Running only one fixture at the same time will not kick on the water heater.
You have tankless water heater, and no error code.
Burner does not activate with one faucet, but activates with 3 faucets.
Best suspect is crossover:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Problem can be a combination of causes including Tankless part failure: sensors are not working, PC board is bad, wires are loose. Call service technician to catch up on yearly maintenance and troubleshoot problem. Tankless water heaters require yearly maintenance.
Jul 21, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Have an Ecosense Tankless Water Heater with error code C7. It then flashes to 76 degrees and gives cold water. How do we remedy?
Before calling service technician, open following links for troubleshooting resources and typical manuals.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Many causes for common error codes are covered in the yearly maintenance.
Jul 18, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Code 11
Before calling service technician, open following links for Rheem troubleshooting resources including error codes.
Error codes are considered start-point for troubleshooting.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error 11 is no ignition.
This problem can probably be solved by routine yearly maintenance shown in instruction manual which recommends: Yearly cleaning, adjustment and inspection of burner and combustion parts.
The yearly maintenance would check incoming gas supply, venting, wiring and grounding, and burner and ignition parts.
All gas water heaters today require same maintenance: tankless require yearly, and tank-type require periodic (1-3 years)
Jul 03, 2011 | Rheem Tankless Hot Water Heater...
"yearly Maintenencae" what is
thay clean and change the o-ring the needly seat and new diaphram its some thing that you do every year to certifi for ins. purposes
Apr 23, 2011 | Scubapro MK25/G250 Hp Regulator
Gas outdoor mounted AQ250 won't stay lit. Unit is about 2 years old and has been working great.
Before calling service technician, open following link for Bosch troubleshooting resources.
Sample manual has troubleshoot section and yearly maintenance requirement.
http://waterheatertimer.org/pdf/Bosch-250SXO.pdf
Service bulletins for 250SXO
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
Tankless require yearly maintenance as outlined in manual.
No tankless manufacturer suggests do-it-yourself repairs on their product, in part for liability and danger to customers, but for long-term customer satisfaction.
Repairs and yearly maintenance will eliminate the $1-8 monthly energy savings expected from owning tankless.
Apr 19, 2011 | Bosch AquaStar 2400ES-NG
Unit wont run and thers no error code
1) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
http://www.rheem.com/hrc.aspx
2) Call local service technician, and put that person in your rolodex-wallet for future help.
When technician arrives, ask that person for tips and tricks keeping unit working with regular maintenance.
They will gladly offer yearly service.
3) Read manual several times get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
4) Read manual several times and notice word troubleshoot appears many times.
Since tankless are complicated machines, many internal and external factors can affect operation, especially as unit ages.
5) Look at label on unit to identify exact product number. Identify same/similar product at Rheem, and become familiar with Rheem website
6) Read other question/answers at fixya about Rheem tankless to become familiar with the tankless era
http://www.fixya.com/tags/rtg_74pvn
7) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 16, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
BOUGHT THE UNIT IN JULY 2009 WORKED FINE UP UNTIL THREE DAYS AGO WHEN I RUN THE HOT WATER IT RUNS FOR A FEW MINUTES THEN SHUTS OFF.
Ask technician for tips and tricks for keeping unit working and needed maintenance.
They will gladly offer a yearly service.
3) Read manual several times to get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
Mar 14, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
Scubapro MK25/G250 Hp Regulator Logo
176 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
