Question about Polaroid TLA-01511C 15 in. LCD Television
Our Polaroid Model TLA-01511C has started sporatic visability. The light seems to go out. You can still see the image very faint in the background. Is there a part (Light) that we can replace that will extend the life of this TV?
Posted by danstacy on
Shawn O'Halloran
  • 345 Answers
It sounds like your backlight is beginning to fail.
Posted on Apr 23, 2011
I need the manual for a polaroid tla-01511c manual free
Try Googling (polaroid)(tla-01511c)(manual) without parens.
Sep 25, 2017 | Polaroid Televison & Video
My Polaroid TLA-01511C has sound but no picture...what do I do
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Feb 21, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Sound no picture Polaroid 15.4 TLA-01511c
If you take a good look at the screen when it goes dark can you make out anything maybe some bright scenes on the channel you were watching or if you press the menu key, you can see a very dim display, you might need the back light assembly or something related to it.
Jan 09, 2010 | Televison & Video
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Problems with Polaroid TLA-01511C 15 in. LCD Television
It needs a video board replaced most likely. You can find by searching on google for your model. Might cost more than set is worth. Think about new model as they are really cheap in that small size.
Feb 04, 2018 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Manual for TLA-01511C
olsonde,
Here is your product info. Please let me know if I can help you in any other way! If not, I would appreciate you rating this as "FixYa".
http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT261&folder_id=0
-DRebel
Apr 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
How do i find the AUX on the Polaroid TLA-01511C? I want to run a DVD player and it needs to be set up on the AUX. If I run a scan on the channels it does not pick up the AUX
I would recommend using the S-video connection for the DVD to the TLA-01511C TV's S-video. Then, press the input button and go down to the S-video option and you should be good to go - it worked for me. Hope this helps you!
Dec 21, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Polaroid TLA-01511C 15 in. LCD Television Logo
182 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
