AMT Datasouth ACCEL-6350 Matrix Printer Logo
MIKE CASTRO Posted on Apr 23, 2011
When im in the forms menu and hit the print mode it seems like it is taking forever to print forms i have a amt accel 6350 and the computer company reynolds they said they installed new drivers it ran real fast for 1 deal they it just seems to roll and not comunicate and it takes printer for ever to print a form thisneed help to make sur defaults are reset and the printer is working thaks mike c
Brad Oberg
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Sep 19, 2013
Brad Oberg
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
8664
Points
44
Real easy Mike. Dump Reynolds and call ADP. The driver that was installed is incorrect. Also try contacting AMT for a current driver.
1 Related Answer
Anonymous
  • 40 Answers
  • Posted on Jul 31, 2009
SOURCE: form feeding
try puting a piece of cardbord under the paper but tape it 3mm from the roller.
HOW DO I REALIGN MY ADP 6350 PRINTER
Not sure what you mean by "realign" but you can try under the test menu select pcalb. make sure there is not paper installed and the printer is not in direct sunlight.
Amt 6350 setup
your printer is locked up of some functions. to unlock hit alt and form feed then setup twice.
How do i adjust the head gap on my amt 6350
There are 2 ways. one is to press and hold setup button. While holding the button turn dial to adjust print density. The second is to enter the operations menu and scroll to the end which is #52. Press form align and config at then same time while scrolling further. Gap adjust is #58. The higher the number the further the gap. Caution. The other setting can adversly affet the printer. Unless youi know what you are doing, do not adjust the other settings.
HOW DO I ADJUST THE TOP OF PAGE FOR A FORM?
when the paper loads, the top of form is then set., If the printer is not setting this or the paper just feeds through when loading paper, go into the test menu, select pcalib and make sure no paper is in the printer. aslo make sure the printer is not in direct sunlight. this will reset your paper detection circut and therefore your tof "alignment"
The printer cartridge moves more than it should. When you get through printing a form, it looks like someone had gotten a pen and scribbled all over the form.
either your head gap is set too close or you print density is too much. To check print density press and hold setup. While holding set up scroll wheel to left to lighten print and right to darken.
During the printing of a form, a noise occurs as if something is catching & it throws all the printing off to either the left or right, right most of the time. any help?
2 things. First oil the inner bar. the one without the red plastic holder. never oil the bar with the red plastic holder. Second thing coud be the bushings inside the carriage assembly. The are brass and have to be pressed gently and very evenly into the assembly.
AMT 6350 printer. 'error' light keeps blinking with 'load paper' flashing. put paper in, press form feed, did not help
Perform "Pcalib". Under the test menu select pcalib. Insure the printer has no paper installed and is not in sunlight. This should fix it.
PRINT GAP WHEN SET ON AUTO IS TOO CLOSE. (RIBBON SMUDGES ON PAPER) WHAT DETERMINES THE STARTING POINT FOR THE GAP ENCODER? DOES THE PAPER SWITCH ON THE CARD GUIDE HAVE ANYTHING TO DO WITH IT?
enter the hidden menu. press setup and scroll to end #52. press and hold form align and config. scroll to 58 gap adjust lower the number the closer the gap is.
Form feeding
Top AMT Office Equipment & Supplies Experts
k24674
Are you an AMT Office Equipment and Supply Expert? Answer questions, earn points and help others
