SOURCE: Miele White Star SEB 204,
Yes, most likely the belt has stretch. Flat belts do this after a short time and need to be replaced when problems start with the brush roll not wanting to turn. Also check the brush roll, make sure that the ends turn freely, if not, then replace it also.
SOURCE: Miele Red Star Powerhead overheats and turns off
be sure at 1st there is no materials blocking the hose then it seems to me your m/c is good if normall condition around
try to test your cleaner by use less length hoses
thanks
SOURCE: No manual...
Here's a link to the USA version of the Miele S4210 Canister vacuum. You may visit this link and download the .pdf file, or just print it out if you'd like to have a paper copy.
http://www.mieleusa.com/manuals_pdf/Residential/Vacuums/S4000_us.pdf
I hope that this helps you with your new vacuum!
Chris J.
GoVacuum
SOURCE: Have a Miele Capricorn. It has been having the
it sounds like it could be an inherent fault if its been mended that many times,dheck up with the local tradeing standards office and ask about sale of goods act if it is proved to be an inherant fault you should be entitled to recompence
