Canon EOS-10D Digital Camera Logo
Question about Canon EOS-10D Digital Camera
LCD Screen on my Canon D10 has stopped working. The light on right is flickering and the screen remains black. I've checked and I can take picture still but impossible to change features and playback and see what I am taking. What is wrong? And how to fix thatT
Posted by anuish33 on
5 Related Answers
Anonymous
SOURCE: Blank LCD works but wont display
I have a Canon powershot A85 camera, and it works fine, but I get no picture in the LCD screen. It does take pictures and I can look at the pictures after I have taken them. I don't know if you live in Australia, if you do ring Canon on 131383. A lot of Canon camera's and also a lot of other digital camera's all have a problem with the CCD Chip. My brother has a Canon A75, he has had is for many years, and they fixed it free of charge, because it is a problem the camera has, so not something we done. Look on the internet and you will find a lot of info on it, also that it will be fixed free of charge. I also found the same information on a lot of other digital camera's, so ring Canon and find out, I hope this helps you. Kind Regards Marion
Posted on Oct 31, 2006
Anonymous
SOURCE: Canon Powershot has black LCD screen
Best Solution worked for me?!?!?. Not sure if following the instructions got the screen to come back, but it did come back. I just flipped it over to movie messed with the settings and then open up the battery door which turned off the camera. Closed the door, Flipped to photo and turned it back on and it workd. This is the second PowerShot that I have had, current SD750 and an old S230, to do this.
Posted on Jul 16, 2008
Anonymous
  • 10594 Answers
SOURCE: Canon PowerShot A60~~~Viewing screen black/fuzzy won't take pict.
Its known problem of ccd imager in Canon A60 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Posted on Jul 24, 2009
Anonymous
  • 10594 Answers
SOURCE: lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Posted on Dec 23, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Posted on Feb 28, 2010
1helpful
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Screen not working on Canon powershot D10...takes pics but screen is black.
This is obviously a lack of power flow into the LCD. It could mean many things. All you need to do is; take it into a service centre for a check up and repair.
Don't attempt to fix it yourself.... if you value your camera, you need to accord it proper service ... and care.
2answers
My canon powershot d10 underwater still takes photod but the screen in blank.. Help can I fix this?
dear user,
its screen is faulty because of water dip.is only can replace the lcd of your camera
Regards
Salman
Pakistan
1helpful
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
3helpful
3answers
First inmersion with Canon D10.Display went off, never recover. But it seems the camera functions, as it takes pictures. I d br grateful is someone helps me, its my second day of holidays, it is not fair!...
Apparently, you got a camera with an lcd screen that leaks. If it's still under warranty, get Canon to fix or replace it. I know that doesn't help you on your vacation.
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
2helpful
LCD Screen remains black
Hi!
Have you tried pushing the DISP button while taking pictures? It's on the right from the LCD.
Tom
3helpful
Screen is black
Eagle 23: Press the "Disp" button and your LCD screen will turn on right away.
nazmil_mj: Can you take pictures or are they totally black as well? If you can only take black pictures then your LCD screen is fine and your CCD is bad or your aperture is stuck. Either of these means you need your lens replaced.
Don't bother asking a store for help (though you can if you like) they will tell you it's not fixable or will just send it to Canon and charge you $175 for the repair.
We are an affordable digital camera repair business, we can replace your lens for about $75!
Thomas
Owner- Darntoothysam com
2answers
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
