Yes the horn should sound when connected directly to a power 6volt dc power supply like a battery, the power supply to the horn on a dt250 is the same supply as the brake light and indicator relay, the supply is constant when the ignition is on, the horn button then completes the circuit by earthing the horn out when pressed, simple test on the bike connect live wire to horn, using a length of wire earth out the other pole on the horn to a clean part of the frame, and the horn should sound
Does the horn have 2 wires or 1? Newer Yamahas have 2 wires....power to the horn, and then a ground wwire that goes through the horn button. If its a 2 wire....jumper the ground wire to a good ground to try the horn...if that works...check the horn button.
If its a single wire horn...ensure the horn is firmly grounded.
