The motor needs the bearing oiled...to do this you will need to get a bottle of oil at your local HVAC supply house that has a long pull out spout on it... then place a few drops of oil on the shaft by the motor... if possible then tilt the unit so that the oil will run back the shaft and then get the motor to run... the oil will work its self into the bearing...this will lube the bearings and free them up... you will have to do this for both sides of the motor...
If the motor has little tubes sticking out also place a few drops of oil in each tube...
heatman101
