Question about Proton MM2701VT 27" TV
I have a 50 inch sony projection television model number KDF50E2010 my problem is it cuts out after a half hour i then turn it back on and it shuts itself down again and again
Posted by floormaster6 on
gregorio jr ballena
    New Friend:
  • 138 Answers
There's a lot of troubles the unit. its probably cold soldered, capacitors needed to replaced, defective power supply and regulator. if you see plenty of moist of capacitor in the surrounding it means you have to replace it, enlarging case or melting tag. some capacitor their feet get rust seem all part were getting worn out. try to soldered the feet of the component maybe there were ring o circle on the lead. There were some cases in physical appearance when you staring on the lead its okay but in the inside where not. i usually was to re-solder stage by stage. then look if improvement on your work. ask me again if nothing happened.
Posted on Jun 25, 2011
My Sony t.v model number KDF50E2010 it turns on but no picture and make a cracking sound
first check lamp if lamp is good,your ballast may be bad,normally it's the lamp.
Aug 16, 2014 | Televison & Video
The bulb has gone in our tv
If you Google the model number of this set with the word lamp after it---you will find many places that will sell it---from about 109 dollars and up---make sure you get a lamp with the cartridge---the cheaper ones usually are just a bulb and you have to dismantle the cartridge and install the bulb your self into it.
Usually better to buy a complete lamp with cartridge that comes with a warranty.
If you have any questions or need help let me know-I am here to help people.
Regards, SD TECH
Oct 06, 2009 | Televison & Video
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Jun 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Changed Lamp on KDF50E2010 now have pink band
Is this on all inputs.If so optical block could be bad.
Apr 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
My Polaroid 42 Inch LCD Keeps shutting off.
This might sound a little crazy but, i had the same problem with my rca 50 inch, and he changed the bulb. which are pretty $$$$$125.00 at my tv repair person cost. the real cast was $219.00.Hope this helps you
Dec 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Proton MM2701VT 27" TV Logo
46 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
