Question about Kenmore Dishwashers
No water going into dishwasher - Kenmore Dishwashers
  • 2,510 Answers
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Posted on Apr 23, 2011
6ya staff
SOURCE:
Changed the washer, turned tap and dishwasher on but water won't go through to dishwasher
Might be better to check if the water is coming out of the tap. Also confirm if you are getting any error code on the dishwasher.
Feb 06, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
No water going into my dishwasher . Water is running in my sink but none going to the dishwasher
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 17, 2011 | GE Dishwashers
Water will not go into the washer. We check the hoses .and still the water does not go into the washer.
Here is a tip that will help you to find out why water will not come into thedishwasher...
heatman101
Oct 15, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
No water going into to dishwasher all of the sudden.
check water connection to bottom of dishwasher (left hand side) if you have water going into the valve but no water coming out of the valve theres the problem check to also see that you have power to the valve
Apr 29, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
Water is not going into beko dishwasher de2542f .you can hear and feel water going through the pipe but is not going into machine
My BEKO dishwasher is turned off but there is a constant dribble of water running in to the machine. If I open the door when this has happened, it leaks water all over the floor. This means I have to keep turning the machine on to drain the water away.
Feb 06, 2010 | Beko 24 in. D3731F Free-standing...
When I start my dishwasher water wont go into the dishwasher.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jul 18, 2009 | Dishwashers
Water doesn't run in to clean dishes
if the water line not blocked or pinched... then I would your fill valve.. it may not open all the way...before replaceing the water valve...check that the water is come into the dishwasher but maybe going out the drain..If the drain hose is too low water will run out before the dishwasher can run a cycle... to check it it must raise above the bottom of the sink ... this keeps water from running out and sink water from going into the dishwasher... let me know if it helps
Jan 29, 2009 | GE 24 in. PDW7880JSS Built-in Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ron Rak
Ron Rak
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
