Question about Nikon COOLPIX L4 Digital Camera
SOURCE: Nikon 5400: white lines on photo
There is a non user repair fault here If it is just out of warranty contact the maker Tech support They sometimes can offer a 'refurb' one at an agreeable price in exchange.
Posted on May 15, 2007
SOURCE: Nikon D50 LCD
It sounds to me that there is moisture in the camera. Send it to a repair centre.
Posted on Dec 11, 2008
SOURCE: Suddenly unable to transfer photos into Nikon Picture Perfect
How are you transferring the photos? Are you using a cable, or a card reader? If you are using a cable then most likely the cable went bad. I have a D-1 and a D-2, and I never use the firewire cable. I put the CF cards into a card reader. If you are not using a card reader then try that. You can get a decent one from E-Film or from most any computer store.
One more step to try, did you format the card in the camera when you first loaded the card in? On my cameras you need to format that card to have them work with the camera.
Posted on Dec 18, 2008
SOURCE: sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
Posted on Jan 19, 2009
SOURCE: LCD on - view image prior to taking photo
The feature you are referring to is called "Live View mode".
This is NOT available on the Nikon D80, and was only introduced on the D90, which is available now.
Live View mode allows you to use the LCD screen as your view finder instead of using the eyepiece, but unfortunately, this feature is not available in your model.
Posted on Jan 20, 2009
