Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
How do i set the linksys spa2102-r back to factory settings
Posted by mznikee on
joecanadian
    Problem Solver:
  • 10 Answers
**** 73738 #
the 1 to accept
Posted on Aug 14, 2014
Anonymous
  • 79 Answers
Unplug the unit. Using a ball point point push down the reset button. While pushing the button down, power up the unit. Continue to hold the button down for 15 seconds or until you get a visual indication on the front panel.
Posted on Apr 23, 2011
Spa2102-r does not connect my phone. My new ISP does not help me to make a configuration. The unit worked perfectly with the earlier ISP.
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
I am using SPA2012 with TG585v7 ADSL on PPPoE, i am not getting any incoming calls, my out going calls are ok. I have done port forwarding still no solution. When i run same SPA2102 on linksys ADSL it...
I have problem with my spa2102 such as when incoming call there is no ring on my analog phone other than that everything is fine. Thanks.
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Good Luck
How to reset linksys spa2102-r phone with router . i dont have any username and password. there is no reset button in the device. so i need some help for configuring this one for VOIP. this product...
Good Luck
HOW TO SET UP LINKSYS PHONE ADAPTER WITH ROUTER SPA2102-R
What I have understand from your question is that you just want to get your VoIP device working but probably you may need a SIP account from a VoIP service provider.
1helpful
Linksys SPA 2102
To reset your SPA device to the factory default values, follow the steps below:
1. Disconnect the Ethernet cable
2. Access the voice menu (****) and press 73738#.
3. Login with the username "user" when accessing to http://spa-ip-address OR
login with "admin" when accessing http://spa-ip-address/admin/.
NOTE: Resetting your unit will erase all the configuration settings. If your SPA device was provisioned by a service provider, the reset function might be password protected. Contact your service provider.
We have power but no internet or phone lights are coming on.
do you get dial tone if you lift phone handset?
If so, Do you hear the voice menu after pressing ****?
If not, please unplug the Ethernet cable, and press **** again, then check if you now hear the voice menu?
Just in case you are able to access the IVR, reset it back to factory default settings. Dial 73738# and press 1 to confirm the reset.
2answers
Need a password for factory reset
8helpful
5answers
Password recovery on SPA2102
You may try to set to factory default. from the phone you can perform Factory Reset, Press 73738 then Press 1 to confirm.
Press * (star) to cancel.
If necessary, enter the password. The Phone
Adapter will request confirmation; enter 1 to
confirm. You will hear, “Option successful.”
Hang up the phone. The Phone Adapter will
reboot, and all settings will be reset to their
If you need further assistance please post your question
You idiot, the problem is, he doesn't have the password, how is he going to do that without it? If you're going to offer advise in here, make sure to read the entire problem first before blurting out stupid or ignorant sh*t that has nothing to do with the problem itself.
Top Linksys Computers & Internet Experts
Donivan Wise
Mike
Mehandi Husain ...
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
