Okay the switch is in the back trunk area(I know it a SUV) in the back where you access the jacking tool youll see the switch make sure its on. Now some Navigator some have a shrader valve to pump up the suspension on the front area on driver side. As for the relay you might have to use a enhance scan tool to command it.By the way do you have a misfire?because if there is a misfire it will not inflate or a ABS light on? thse will also cause the suspension to not inflate
