Question about Refrigerators
Fridge verynoisey when fridge door is shut, quite when opened. now inside fridge getting warmer. where is temp control located?
Posted by winniedinnal on
Victor
    President:
  • 1,136 Answers
Hi, Sounds like the evaporator fan blade is hitting something. Probably frost that is building up behind the rear freezer wall. Can you see fros on the rear wall? The fan shuts off while the door is open, so that is why is quiets down when you open the door. I hope this helps locate the noise. If I can assist you further, please let me know. I an help you with the defrost problem if there is frost building up.
Thank You, Vic
Posted on Apr 23, 2011
How do i set temperature
Most fridges have only a plastic dial located somewhere in the rear of the food space inside the fridge that simply says "cooler" or "warmer" Turn this dial to change the temperature. If you want to know what the temperature is you will have to put a thermometer inside the fridge for a few minutes , open the door, and quick read the temp before the thermometer warms up. I keep a cheap thermometer with a large dial with a red indicator inside my freezer all the time and that way I can see how cold it is every time I open the freezer.
Oct 30, 2014 | Freezers
I have the samsung upside down fridge 590 litre freezer is great but the fridge is showing it is set on 3 degrees but inside the fridge it is 7
For starters, Get a second thermometer to check against those two.
Also leave the freezer closed to several hours and see what the difference is in temp.
I would expect that the inside temp would mostly be warmer than the 'set' temp., as the latter is always trying to catch up every time the freezer door opens.
Oct 24, 2013 | Samsung Refrigerators
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Refrigerator 1/2 temp will not get warmer than 28 degrees
try and replace the thermastat control.
turn both knobs to the off position and listen i the fridge for the cold air damper to close it is located top left side rear of the cabinet in the fridge if the door does not close then you may need to replace the damper
Apr 13, 2010 | Frigidaire FRS26R4A Side by Side...
Whirlpool gold side by side refrigerator is not cooling correctly. Inside temperature on setting of "6" was 41 degrees. On "5" it read 39 degrees. Noticed that it seemed warmer than usual yesterday and...
Greetings,
I'd be looking at a froze over evaporator.. The freezer usually will seem okay, and the refrigerator will be getting warmer. however, after awhile even the freezer will go out if its froze up.
The thing you need to do is determine if your freezer evaporator is frosted. If so, the air will not be able to draw thru the evaporator and get over to the fresh food section. So, defrost the coil if it is froze up and this will give you temp service.
Its difficult to troubleshoot this,but if you have a ohm meter, you need to check the resistence of your heater and defrost thermostat. if these are good..Its possible your adc is defective..9The timer)
Sep 25, 2009 | Whirlpool Refrigerators
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Refigerator is freezing food
Hi, this problem is going to be with the running thermostat. It has gone bad and stays open which in turn will keep the compressor running continually. It can normally be located in the control panel inside the fridge. Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Maytag side by side refrigarator Mod, RSW2400EAE refrigarator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 16, 2009 | Refrigerators
REFRIG SIDE NOT COOLING
The sweating inside is from the door not making a proper seal, and you are getting condensation build-up. The door not shutting is not as unusual as you may think. First check the gasket condition, a new one may not be a bad idea. On these refers with the revisable doors, try removing the freezer door and then loosening the fridge door hinges and adjusting the mounts. Its a trial and error procedure so don't get frustrated. Another trick is to wad up a wash cloth into a ball and wedging it into the door gap after you open it on the hinge side, then close the door. You should have some tension, but not too much. This bends the door a little. If you can get the door to make a good seal it should solve the other problems with the temperature. If not, you are going in the right direction by locating and cleaning the vents. All the cool air in the fridge comes from the freezer.
Nov 13, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
