Most hybrids are compatible with any CR2430 coin cell battery, which allows them to hold a charge for 4 to 6 months. Swapping in a new coin cell lithium battery can be done easily and in just a few simple steps, plus CR2430 batteries are available from most retailers that sell batteries.
there is different kind of batteries no need of s no . Go to store ask model no battery . There are china made also avilable but i personally say that you take lg battery.
hi there! If you're having a problem with bluetooth then ill be advising you to powercycle your phone and you can do that by removing the battery on your phone while the phone is on.After that reinsert the battery and turn on the phone again and try turn on your bluetooth again.Kindly check as well if your phone is fully charged because bluetooth will not work that good if the battery on your phone is not fully charged.Kindly check as well if the device your pairing with through bluetooth is compatible with your phone because there are devices that are not compatible with each other. If the battery is the problem then try doing the rebooting or powercycle process of the phone.If its still not turning on then kindly charge the battery for a maximum of 4 hrs.Please check if the battery is holding a charge.If it still not working after doing that then there might be a problem with the battery.Kindly replace the battery so that you can use your phone. Thank you!
Hi there! If you're having a problem in turning on your phone then ill be
suggesting you to please remove the battery in your phone then
kindly wait for about 15 seconds.After that please turn on your
charge.If it still not turning on after doing that then there might
be a problem with the battery.Kindly replace the battery so that you can use your phone.If you already replace the battery and you're still having the same problem then there is a probable problem with the phone itself. Kindly contact the manufacturer of your phone. Thanks!
hi there! Basically, you're phone is freezing that's why the boost mobile logo stays on and not going to any other menu on the phone. If you're having this kind of problem then ill be suggesting you to please remove the battery in your phone then kindly wait for about 15 seconds.After that please turn on your phone.If its still not turning on then kindly charge the battery for a maximum of 4 hrs.Please check if the battery is holding a charge.If it still not turning on after doing that then there might be a problem with the battery.Kindly replace the battery so that you can use your phone.If you already replace the battery and you're still having the same problem then there is a probable problem with the phone itself. Kindly contact the manufacturer of your phone. Thanks!
Take out the batteries and check?Very small long tube battery kind?That the AAA kind of bateries.Long tube battery kind?That the AA kind of bateries.Square battery kind?That the 9 Voltage batteries kind.
Make sure you have the right kind of batteries. These kinds of cameras can use the batteries very fast if they are not the correct kind recommended by the user manual. Read the user manual. If the camera works correctly, and takes pictures and movies okay, and still uses batteries quickly, then more than likely, the batteries must be the wrong kind. Never use the cheapest kind of double-A in these cameras. If you use rechargeable batteries, make sure they are charged fully before using the camera.
Try this: Turn the camera on, make sure that the menu setting for the kind of batteries you have installed is set correctly. If you set the wrong kind of batteries, the problems you are having is a common thing. Also turn the camera on, then set all the menus to the default settings. Then make sure that the kind of batteries you are using is set in the menu as (if alkaline set it so... If rechargeable, set so ... other options may exist in menus).
