LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
500 gb just stopped working lights flash with three blips and a pause and then repeats try's to spin up but won't tried different power supplys etc.
Brian Sullivan
Level 3:
  • LaCie Master 27,725 Answers
  • Posted on Apr 22, 2011
Brian Sullivan
LaCie Master
Level 3:
Answers
27725
Questions
Helped
5664289
Points
79191
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active until turned off.
make sure that your RAM is securely seatedjust replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Buffalo HD-LBU2 not reconised by computer
Try a drive dock on the Removed Hard drive. The usual problem is the enclosure.
I have a Buffalo hard drive 500 gb, it has just stopped working green light comes on and it sounds like it is fireing up but stops light stays green no autoplay through my laptop I have also tried on other...
The power-supply seems OK, since you can hear it spinning, and the lamps are lit.
So, either the USB-to-disk-drive interface has failed, or the disk-drive itself has failed.
Open the enclosure, and remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer, to see if it works, when you bypass that 'USB' interface.
1helpful
I have a LaCie d2 Quadra 500 gb. external hard drive. It is just over three years old. Recently, it suddenly stopped working. No light or fan when powered up, and the hard drive does not spin. No longer...
this drive rarely has a power switch issue beside the fact that sometimes it gets misaligned and cannot be properly put in the ON position because of the aluminum casing. If you tried powering on while the backplate is removed and still nothing, look at the soldering of the power switch. If the switch connectors are still all in place, the problem lies more with the power module.
A total lack of power would usually result from the power module being "cooked", so look at traces of burned and cracked chips near the power supply connector on the interface board. If all seems good, make sure the power connector is also correctly soldered.
If the power module is burned, you can replace the interface by buying a used one, but in most cases it is easier and cheaper to buy another enclosure like you did.
Regards,
Maxtor Personal Storage 3200 500 GB Hard Drive suddenly not recognized. Light on, tried alternate similar power supply, tried different computer along with different operating system. Please help.
May be your Personal Storage 3200 500 GB Hard Drive power socket pins are not seated well when you connect so make sure the pins are in good condition.
Think this is helpful !
500 GB HD stopped working
plz check the drive spin up when u connect to power
dont use front panel usb plz use back panel USB
Green light, followed by yellow light flashes 5 times, then green again. Print screen says operator error, press printer's resume button.
Hi there
You can try not really know but it like your waste ink needs to be reset.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Wait until print head stops moving
5. Press RESUME four times (if four doesn't work try three times)
6. Press POWER once
7. Press RESUME four times (if four doesn't work try three times)
8. Press POWER once
Repeating the RESUME/POWER code twice made the difference, the fixes I found wouldn't work because they stopped at step 6.
Doesn't spin & Power light flashes red to green
This situation indicates a problem with the built-in self tests. Most likely a power supply failure. I don't believe it is economically feasible to replace the power supply. If it is still under warranty, I'd go through the procedure to get it repaired/replaced. Otherwise, you'll need to replace the unit.
2answers
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
